3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Worm bin bag for indoor vermicomposting and easy separation of worms from compost
Step 11Start assembly of wood frame
Get your drill, your drill bit, philips head driver bit, 1 1/4" screws and wood glue ready.
The drillbit is for making pilot holes before putting in the screws. Trust me, you need the pilot holes. If you are cowboy-ing it and skipping the pilot holes, don't be mad at me when your wood splits.
The pilot hole drillbit should be about 1/8", or slightly thinner than your wood screws. You'll also need a philips head driver bit to screw in the screws with your drill. Special bits that make this all go faster are a magnetic quickchange driver that fits into the drill chuck and a quickchange countersink drillbit, which will slip into the magnetic driver and drill a pilot hole at the same time as drilling a countersink divit into the wood that will allow the screw head to go in flush. It pops out of the driver magnetically, so you can pop in your philip's head bit to do the screwing part, all without undoing the drill chuck. Totally worth it! Check it out in the detail pics.
Lay out 2 of the legs (24" long wood) and one of the long sides (17.5" long wood) as seen in the main pic. Wood glue needs to be connecting the pieces that are touching, so flip the side piece upside down to apply wood glue on its ends and flip it back over.
1 comment
Mar 12, 2010. 2:51 PMjwm.herbert says:
Word of advice to others:
-- READ AHEAD to the next several steps FIRST!
Don't assume you'll do exactly the same thing for each joint.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:amyoungs
