3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wormery (Worm Composter)
Step 4Adding the mesh
Adding the mesh
For each box:
Cut the mesh to size using tin snips.
Then lay the mesh into the bottom of the box and using a marker draw six dots where the split pins will go.
Then remove the mesh and drill 4mm hole on these dots.
Placing the mesh back in, push the split pins through the holes ensuring one leg goes either side of a piece of the mesh and open out underneath.
3 comments
May 8, 2009. 6:06 PMhalrob says:
Would steel window screen work for this or would it not allow for good enough drainage?
Mar 21, 2009. 1:39 PMNumpad says:
Could you not use a staple gun for this bit?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:pudtiny
