Woven paracord bracelet/watchband
 by Stormdrane
Featured
This tutorial will show how to make a paracord bracelet or watch band using a weaving method. More knot work with releated links and resources can be seen on my blog page, Stormdrane's Blog.
Step 1: Supplies
For this project, you'll need approximately 10 feet of paracord, scissors, lighter, tape measure, hemostats, watch, and a 5/8" side release buckle. I used a 5/8" ITW Nexus contoured side release buckle, but you can use other less expensive ones like those found at Creative Designworks.
Paracord can be found at local Army/Navy stores or from various online sources: Supply Captain, Lighthound, Cool Glow Stuff!, ebay, etc...
The actual amount of paracord that will be used depends on your wrist size. My wrist is about 8.5 inches and I actually used around 8 or 9 feet after finishing the bracelet/watchband. So using 10 feet is a safe estimate for most folks, since having too much cord is better than coming up short when making your project.
*If making a watchband, the watch needs to have about 5/8" space between the lugs(where the watch pins go) so that 5 strands of paracord will fit.
Step 2: To begin
Measure about 20 inches from one end of your length of paracord. This is where you'll loop onto one end of your side release buckle. Once attached, you'll have the longer section which will be your working end and the shorter end which is just attached to the buckle ends and will be tucked in when finishing the bracelet/watchband.
Step 3: Add the watch and adjust for wrist size
If making as a watchband, this is where you take the strands of paracord from the looped section of the buckle and run them over the watch pin, under the watch, and over the other watch pins. Then you loop the paracord around the other buckle end twice.
At this point, you'll measure the distance between the buckle ends for your wrist size. The distance should be equal to your actual wrist measurement. The weaving process will stretch this original spacing of bracelet/watchband about another inch after tightening as you reach the finishing point.
*Don't include the prong section half of the male end of the buckle in your measurement. It is snapped into the female half of the buckle when worn and isn't used in figuring the wrist measurement.
Now bring the cord ends back thru the watch pins, along side your first pass, and around the starting buckle end.
*If you're just making a paracord bracelet, you'll just be going from one end of the buckle to the other without adding the watch.
Step 4: Begin weaving
Now you begin weaving the long working end of your paracord. The shorter end will be left out until it's time to finish the bracelet/watchband, and tuck it into the weave.
This weaving process is called 'weaving with three warps'. You'll be going around the outer cord with your working strand, under the center two cords(which you treat as one cord), and around the other outer cord.
You weave it back over the center two strands and around the outer, continuing this process, back and forth. Try not to leave too much slack as you go to keep the weave uniform. Every couple of weaves, push your work tight, up towards the starting buckle end.
Step 5: Threading the watch
Once you've reached the point where your watch will be centered, push the watch tight against the woven cord and bring your working strand thru the pin along side the other cords under the watch, and back thru the other pin.
*If making the bracelet, there' s no watch in the way, so just keep weaving. ;)
Step 6: Continue on the other side of the watch
Continue weaving the paracord, keeping a uniform look, and tightening as you go.
A pair of hemostats can help work the cord around as you get close to the buckle end, making the last couple of weaves.
Step 7: Finishing up
To finish up, you'll take the working strand around one of the outer cord, so it's coming thru the under side of the bracelet/watchband.
*Check for a good fit on your wrist at this point. If it's too loose or too tight, untie, adjust your starting measurement longer or shorter to correct, and try again. I have to do this myself sometimes. ;)
Take your hemostats and work them thru about three of the center weaves, towards the buckle end. Grasp the working strand and pull it back thru the center weaves.
Trim the end with your scissors, quick melt the end to prevent the cord from fraying, and tuck it under the weave.
Now do the same with the shorter end of cord and you're done.
If you measure again, you'll see that the finished length is about 1 inch longer than the starting measurement. This will vary depending on your tightening of the weave as you go, but should make for a loose/comfortable fit.
Enjoy!
*Anyone that's worn a nylon/paracord bracelet/watchband knows it can get dirty and smell funky after a while of use. I use an old soft bristle toothbrush to scrub with soap/water in the sink to clean it(while it's on the watch(hopefully yours is water resistant/waterproof), and let it air dry overnight.
*A note on paracord shrinkage:
Ubraidit.com mentions that paracord may shrink as much as 10%-12%(especially black and kelly green), so they recommend soaking the cord first. They note that it's the inner strands that shrink, not the outer sheath. I believe they use 450 or 650 grade paracord, which I think, has a few loose fibrous polyester filler cords instead of the usual 7 twisted nylon strands, found in 'Type III 550 mil-spec paracord which isn't supposed to shrink up. I've mostly used the mil-spec type paracord, so if it's shrunk on me, it's not noticeable. YMMV ;)
1-40 of 304Next »
Stormdrane (author) in reply to MrsHillOct 25, 2012. 2:30 PM
For many more possible new and old knots and ties to use as bracelets, fobs, lanyards, straps, etc..., it's worth a visit to see JD of Tying It All Together's YouTube channel and Forums, and more on the Parachute Cord Crafters group on Facebook. KHWW.net also has much to offer for those interested in knot work.  :)
1980madman says: Jun 14, 2013. 8:07 PM
@ bcosta3 - you don't have to buy expensive buckles and pay extra for shipping... go to a local pet store and buy a dog collar - the buckles will work just as good.
bcosta3 says: May 24, 2013. 8:18 AM
Man, I can't find where to buy these contoured side release buckles that sends their products to Brazil. I really want to make one watchband like that.
D:
dchristyandjeff2000 says: May 13, 2013. 1:57 PM
I am trying to take this design and make it into a belt, basically put more stands and used a hitch knot onto a belt buckle. but I'm having trouble keeping the weave tight in the first few rows. do you have any pointers or tips?
Stormdrane (author) in reply to dchristyandjeff2000May 13, 2013. 2:18 PM
You can use an improvised marlin spike tool, like hemostats or a clay stylus, to help work out any slack every couple of rows of weaving.  And push your work up towards the starting end too, to help keep the work tight.  Hope that helps. ;)
zpickel says: Apr 13, 2013. 9:59 AM
This is a nice easy design, and it looks great!
robgilmore88 says: Mar 24, 2013. 11:25 PM
Well instructed! Looks amazing...I was able to purchase a para cord bracelet (8ft) and it worked great. Good work stormdrane
Vonnie2 says: Mar 15, 2013. 8:45 PM
Wonder if the paracord could easily be unwound for survival purposes?
Stormdrane (author) in reply to Vonnie2Mar 15, 2013. 9:28 PM
Yes, since it's woven with a single working end, it's not difficult or time consuming to take it apart, should you need to repurpose the paracord. ;)
emilyvanleemput says: Mar 10, 2013. 10:38 PM
this looks really beautifull!
tictaclad says: Mar 9, 2013. 8:49 PM
Awesome instructable, do you guys think it would look good with the Nixon "The Unit"?
whopoder says: Mar 3, 2013. 9:58 PM
Pretty cool! And the instructions are perfect, very easy to do.
Thank you!
Crystalenia says: Feb 15, 2013. 11:15 AM
This looks really great! I just wonder.... how do you change the battery if needed?
Stormdrane (author) in reply to CrystaleniaFeb 15, 2013. 7:13 PM
Simply remove one of the watch pins and you have access to remove the battery cover and replace the battery. Then reinstall the watch pin back over the paracord. ;)
WouterZ says: Jan 24, 2013. 8:04 AM
All thanks to your great instructions and some knot experience due to 15 years of climbing and my sailor school background. The watch is huge (more than 1/2" thick and more than 2" wide) and weights a ton (full stainless), but after 5 years I think it's still one of the coolest watches out there. Now, with the new strap it's updated to modern standards).
WouterZ says: Jan 24, 2013. 1:38 AM
Hi,
I promissed some pictures of my result following this great tutorial.
Hope you like it (this was my first paracord experience and I'm hooked).
Wouter
Stormdrane (author) in reply to WouterZJan 24, 2013. 4:02 AM
Nicely done!  Cool lookin' watch too.  Welcome to the paracord addiction. :)
WouterZ says: Jan 22, 2013. 2:51 PM
Hi, thanks for this great instructable. Now my Taugmeister watch looks even cooler. I used camo green Mil-C-5040 Type III which works great with the stainless steel housing and black dial. I found that I could adjusting the size right up I finished braiding the first half of the strap (using the short end to tighten and loosen it). It fits perfect in one go. It took me about an hour to finish it, and most of that time was spent tightening it and adjusting the size. My leatherman was my best friend in this since I don't have the suggested tool. I'll upload a picture soon.
Thanks again very much!
Wouter
Rick Grimes says: Jan 5, 2013. 5:36 PM
Your Instructable is constructed really well. What is the name of that watch? I know its a Timex, but what model?
Stormdrane (author) in reply to Rick GrimesJan 5, 2013. 6:29 PM
It's a Timex ReefGear, but no model number is visible on the watch itself, just instructions for setting the alarm on the back. I bought mine 13+ years ago, and it keeps on ticking, as long as I change the CR2016 battery when needed.
The one I have looks to be discontinued, although there are still some 'ReefGear' models out there. They vary in design and some look to have narrow lugs that may not work with multi-strand paracord watchbands...
clutz2 says: Dec 20, 2012. 5:13 PM
Thank you sir, your instructions were very helpful. Props to you for making them so detailed and thorough. With no prior paracord or weaving experience, I was able to do this in merely 30 minutes. Here is a picture of the finished project. I used olive drab paracord on a battery-free, self-winding watch. No power, no hassle. Something that will be dependable for a long time. Thanks again!
misses_soulful says: May 7, 2010. 6:00 PM
Made one for my husband for Valentines Day (what a cool wife, right? :P) but took me forever to finally take a picture of it. Thank you for the Instructable! He loves it. It was easy, but it took some elbow grease because I'm a perfectionist in making each one tight as can be. I ended up taking it all apart and remaking it 3 times since I kept getting the sizes wrong. :( Also, it was difficult getting the 550 cord through the watch we bought. Heads up for you folks that plan on making it, its tricky to get the exact size. I stopped remaking it because I worry I'll snap the pins on the watch. Thank you again! :) :) :) now I want one too.
Stormdrane (author) in reply to misses_soulfulMay 7, 2010. 6:50 PM
Nicely done!
misses_soulful in reply to StormdraneDec 17, 2012. 4:27 PM
Years later, my husband still gets TONS of compliments on the watch. Thank you so much for teaching me! I still think it's better looking than any I've seen on the market. Can't thank you enough. Happy holidays to you and your family! :)
misses_soulful in reply to StormdraneMay 7, 2010. 8:36 PM
thanks!! :)
Masofhan says: Nov 29, 2012. 4:03 PM
Is it possible to make this using 2 different colours on the thread?
Stormdrane (author) in reply to MasofhanNov 29, 2012. 5:31 PM
Using two colors doesn't work with this instructable, as I tied it with a single working end weaving around the core strands.
You can do a similar looking two color pattern with two working ends by following tutorials that show how to tie the six pack/ladder rack/trilobite knot.
Softballgirl97 says: Nov 3, 2012. 10:22 AM
Where did you buy the watch faces??
Stormdrane (author) in reply to Softballgirl97Nov 3, 2012. 11:13 AM
The watch used in the instructable is a Timex ReefGear that I bought years ago and is no longer made/discontinued. Whatever watch you end up using, it just needs to have room for the cords to fit over the pins and between the lugs of the watch body.
All watches are different, so some will work, some won't, you just have to find a suitable model for the paracord watchband.  You can still tie the paracord bracelet without a watch... ;)
kaperdomo says: Oct 31, 2012. 9:12 AM
could I use matches instead of a lighter???
Stormdrane (author) in reply to kaperdomoOct 31, 2012. 5:22 PM
Any heat source that can be used to carefully melt the ends, without melting/damaging the surrounding cord, so that they don't fray, will be sufficient.
You can use wood burning tools and soldering irons as well as lighters, and you can tuck the cord ends instead of melting, sewing, or gluing them too, with various finishing methods, just a quick melt with a flame is simply the quickest/easiest method with the others taking more time.
The hot melted paracord can burn, so as always take care and knot responsibly... ;)
doggynurse says: Sep 16, 2012. 4:25 PM
So I made the braclet using the ladder rack however my husband wants a gun sling, I like your method compared to others I have seen, do u know what the inches to feet ratio is, like on the cobra weave, they say roughly one foot of cord per inch, so I'm wondering for roughly 27 inches how much cord should I cut for use?? Braclet is pretty awesome by the way!!
MrsHill in reply to doggynurseOct 25, 2012. 1:40 PM
Oh, wow! Thanks for that idea.. I've wanted to make something for my hubby for Christmas and he needs a sling for a couple guns. This is perfect for that!
Stormdrane (author) in reply to doggynurseSep 17, 2012. 7:40 PM
The amount of cord used can vary quite a bit by how loose or tight the pattern is woven. It's best to over estimate what you need so that you don't come up short when tying a project.
The core strands that will be woven around will use around 10' feet or so before the weaving is even started, so if I were making a 27" long sling, I'd start with a 40' length of cord to be on the safe side.
ArtByNancy says: Mar 5, 2012. 12:55 PM
I have an odd question. I have been braiding cobra weave horse reins. I have lobster snaps on each end. I carefully measure, as the reins must be exactly 8 feet from the tip of one snap to the tip of the other. I clip each end to a stationary object, stretched across a room. As I braid, the line begins to sag. When I finish, the reins have "grown" about six inches!
What am I doing wrong? This has happened on three sets of reins. Is this normal?
FYI, UNbraiding is not nearly as fun as BRAIDING.
Stormdrane (author) in reply to ArtByNancyMar 5, 2012. 1:30 PM
550 paracord is nylon, which can and will stretch a bit, and some types(450 and 650) will shrink, so some folks soak it in hot water and run it through a dryer to preshrink it before tying with it.  Longer projects like reins and leashes may experience stretching or shrinking of a much more noticeable length than you find with smaller bracelet type projects like lanyards, fobs, and bracelets.
I've not tied any horse tack, but I think some of the folks over at ubraidit.com might be able to better help you with your project since they have a lot of experience with your particular task. ;)
ArtByNancy in reply to StormdraneMar 5, 2012. 6:29 PM
Thanks! And don't you guys laugh, but a quick & easy way to pull a cord through a tight stitch is to use a crochet hook.
MrsHill in reply to ArtByNancyOct 25, 2012. 1:38 PM
Genius!
VoodooDali in reply to ArtByNancyOct 14, 2012. 4:18 AM
LoL'd at this just now, I too found crochet hooks perfect for this task but wasn't brave enough to say so. My jewelry kit works nicely as well ;)
lin1256 says: Oct 1, 2012. 1:39 PM
I love this bracelet. Can you tell me how to start and finish this weave with a loop and toggle instead of side release clip? Thank you!
1-40 of 304Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
