3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Woven paracord bracelet/watchband
This tutorial will show how to make a paracord bracelet or watch band using a weaving method. More knot work with releated links and resources can be seen on my blog page, Stormdrane's Blog.
Step 1Supplies
For this project, you'll need approximately 10 feet of paracord, scissors, lighter, tape measure, hemostats, watch, and a 5/8" side release buckle. I used a 5/8" ITW Nexus contoured side release buckle, but you can use other less expensive ones like those found at Creative Designworks.
Paracord can be found at local Army/Navy stores or from various online sources: Supply Captain, Lighthound, Rotokid, Cool Glow Stuff!, ebay, etc...
The actual amount of paracord that will be used depends on your wrist size. My wrist is about 8.5 inches and I actually used around 8 or 9 feet after finishing the bracelet/watchband. So using 10 feet is a safe estimate for most folks, since having too much cord is better than coming up short when making your project.
*If making a watchband, the watch needs to have about 5/8" space between the lugs(where the watch pins go) so that 5 strands of paracord will fit.
256 comments
1-40 of 256next »
May 25, 2012. 2:35 PMBLUEBLOBS2 says:
Here's mine.
May 16, 2012. 7:34 PMBLUEBLOBS2 says:
Is that a Zippo lighter?
-BLUEBLOBS2
May 20, 2012. 6:18 PMBLUEBLOBS2 says:
Awesome.
-BLUEBLOBS2
May 12, 2012. 11:17 AMBLUEBLOBS2 says:
This is one of the coolest paracord projects I have seen.
-BLUEBLOBS2
Apr 30, 2012. 1:29 PMAdambowker98 says:
Does this certain knot have a name?
Apr 30, 2012. 3:35 PMAdambowker98 says:
Thanks! BTW, do you or someone you know of have a fishtail bracelet tutorial or instructable or something?
Aug 24, 2011. 6:47 AMkbrown1835 says:
Thanks for the Instructable. I modified your idea a bit and added a second color for the middle two strands to match the watch face color. My watch is a thick Fossil so I created two sides that attaches to the pins and the buckle. Check it out!
Apr 28, 2012. 8:57 AMbigandtasty says:
would like to know how to do this weave for a bracelet?
Thanks
Chris
Mar 28, 2012. 11:37 AMharriesu says:
This just answered the question I had for Stormdrane. I have a watch that needs to have the back removed for battery replacement, so I wanted to leave the cord off the back to ease that operation. This solves my problem.
Thanks to both of you guys for your awesome designs and willingness to share!
Aug 25, 2011. 3:12 PMzenolijo says:
Neat!
Interested of buying a cheap watch just to make this lol
Apr 16, 2012. 10:28 AM~•SMART•~ says:
Do you know a cheaper watch that can be used for this project? I have gone everywhere in stores to find one, but I can't! It can be online as well.
Mar 5, 2012. 12:55 PMArtByNancy says:
I have an odd question. I have been braiding cobra weave horse reins. I have lobster snaps on each end. I carefully measure, as the reins must be exactly 8 feet from the tip of one snap to the tip of the other. I clip each end to a stationary object, stretched across a room. As I braid, the line begins to sag. When I finish, the reins have "grown" about six inches!
What am I doing wrong? This has happened on three sets of reins. Is this normal?
FYI, UNbraiding is not nearly as fun as BRAIDING.
Mar 5, 2012. 6:29 PMArtByNancy says:
Thanks! And don't you guys laugh, but a quick & easy way to pull a cord through a tight stitch is to use a crochet hook.
Jan 19, 2012. 1:07 AMgdkaufmann says:
Thanks, Stormdrane.
I missed that.
Jan 18, 2012. 12:53 PMgdkaufmann says:
Just curious...
How do you account for different size wrists? I'm very interested in tackling this project, but the wrist I'd wear the watch on is quite small (I usually have 3-5 links taken out of the average watchband).
Thanks.
Great design by the way.
Dec 28, 2011. 7:40 PMTheAmateurArtisan says:
Stormdrane, been reading your instructables for a bit and I saw these stainless steel clasps for the bracelets and watch straps on survivalstraps.com. have you tried them and if so, do you know where to get them? they are a lot more comfortable as others have said but rather than buy it, I want to make these myself.
Dec 6, 2011. 6:40 AM#OccupyInstruct says:
love the instruct stormdrane, you have the dest paracord instructables on here. but one color is kind of bland, could you spice it up a little and make it 2 colors while still weaving it like that?
Dec 6, 2011. 2:53 PM#OccupyInstruct says:
thanks for the help!
Nov 20, 2011. 5:52 PMRobotob46 says:
Do you know of any digital watches that can be used for this?
Feb 12, 2010. 5:34 PMmisses_soulful says:
Did you use a Flat Side Release Buckle or a Curved Side Release Buckle???
Nov 3, 2011. 12:44 PMnclark8 says:
Where can you find the buckles pretty cheap, and that takes paypal besides Ebay?
Thanks!!!
Nov 4, 2011. 7:51 PMdhemmer says:
check out www.survival-pax.com they have many colors and sizes of the slide release buckels and safty side buckles and break away barrel buckles.they have e.l.wood braiding 550 paracord and gladding 550 paracord.with 20 colors of eachof the 550 paracord .@ 6.50 for 100 feet 0r a 1000 foot spool.they ship fast too .
Mar 14, 2010. 6:19 AMTeknix says:
how long are these buckles? I found that 3/4" is going to be ugly long, like it will cover one side of my hand, if I'd want to make 3/4" watch band.
Feb 15, 2010. 9:40 AMmisses_soulful says:
Awesome! Thanks! I ordered the contoured one, it made sense to. Thank you so much for making this tutorial! I will let you know how it turns out :)
Oct 8, 2011. 2:58 AMSundevildaddy says:
Just made this band (without watch).. for aesthetics, I added (2) 1" welded metal rings (from old dog harnesses), overlapped, and configured in an Endless Loop, in the middle of the band, using the outer bight, skipping 2, outer bight (catching both rings) skipping 2, then outer bight, then finishing up the band as instructed.
I was afraid of loosing some of the integrity of the weave, but just ensure I kept it tight as i went.
From a survivalist perspective, you can never have too much hardware (weight/size minimal of course) and these rings, with the para-chord have hundreds of uses.
I, missed the mark on measuring total length at the start, so wound up a little short. Needless to say, my daughter loves it (black para w/ chrome rings).. now I have half a dozen tweens begging me for one... how can a dad say no? *eyeballs Stormdrane... (sarcastic) thanks ;p
lol I love your work - Thank you for the Instructables!
~Sun
Sep 30, 2011. 5:03 AMsrmike214 says:
Thank you! What a great instructable. My watch band came out perfectly from the start.
1-40 of 256next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
871
Author:Stormdrane(Stormdrane's Blog)
"No matter where you go, there you are."
