Step 7Finishing up
*Check for a good fit on your wrist at this point. If it's too loose or too tight, untie, adjust your starting measurement longer or shorter to correct, and try again. I have to do this myself sometimes. ;)
Take your hemostats and work them thru about three of the center weaves, towards the buckle end. Grasp the working strand and pull it back thru the center weaves.
Trim the end with your scissors, quick melt the end to prevent the cord from fraying, and tuck it under the weave.
Now do the same with the shorter end of cord and you're done.
If you measure again, you'll see that the finished length is about 1 inch longer than the starting measurement. This will vary depending on your tightening of the weave as you go, but should make for a loose/comfortable fit.
Enjoy!
*Anyone that's worn a nylon/paracord bracelet/watchband knows it can get dirty and smell funky after a while of use. I use an old soft bristle toothbrush to scrub with soap/water in the sink to clean it(while it's on the watch(hopefully yours is water resistant/waterproof), and let it air dry overnight.
*A note on paracord shrinkage:
Ubraidit.com mentions that paracord may shrink as much as 10%-12%(especially black and kelly green), so they recommend soaking the cord first. They note that it's the inner strands that shrink, not the outer sheath. I believe they use 450 or 650 grade paracord, which I think, has a few loose fibrous polyester filler cords instead of the usual 7 twisted nylon strands, found in 'Type III 550 mil-spec paracord which isn't supposed to shrink up. I've mostly used the mil-spec type paracord, so if it's shrunk on me, it's not noticeable. YMMV ;)
What am I doing wrong? This has happened on three sets of reins. Is this normal?
FYI, UNbraiding is not nearly as fun as BRAIDING.
I've not tied any horse tack, but I think some of the folks over at ubraidit.com might be able to better help you with your project since they have a lot of experience with your particular task. ;)
I was afraid of loosing some of the integrity of the weave, but just ensure I kept it tight as i went.
From a survivalist perspective, you can never have too much hardware (weight/size minimal of course) and these rings, with the para-chord have hundreds of uses.
I, missed the mark on measuring total length at the start, so wound up a little short. Needless to say, my daughter loves it (black para w/ chrome rings).. now I have half a dozen tweens begging me for one... how can a dad say no? *eyeballs Stormdrane... (sarcastic) thanks ;p
lol I love your work - Thank you for the Instructables!
~Sun
can the watch band be woven in 2 pieces?? That way it does not cross under the watch & if needs be, you would have unobstructed access to the watch battery....
I know that it would be 2x the work, but....
you know more about this than I do that's why I ask.
http://stormdrane.blogspot.com/2006/03/blog-post_114288848922910049.html
I never knew hw they wove this cord, Thank you for teaching me how it's done!!
Now that I know how it's done, I have all kinds of project ideas!!!
TY again for sharing!!
I can see this watch band outliving me :-)
looks very good. Thanks for the instructions.
