3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
WowWee's Elvis Alive to The Elivinator Project
WowWee\
Hello everyone, I would like to introduce you to a project that I have started since the first of the year. It all happened when I saw the WowWee's Elvis Alive bust. I have been working on an animated head on and off until I seen this. This was just what I was looking for, a head that moves, turns, eyes that move and a mouth that moves. The Elvis had all of it, so I started to think what am I going to do with it? I started talking about the head on www.RoboCommunity.com and got a lot of ideas but the one that I liked the most was to turn the Elvis into the Terminator. So the name The Elvinator was born. This project is a very hard robot to build and to make the necessary mods including making your own main brain board, constructing the Terminator eye with a glowing red LED, building the jaw piston, re-skinning the face to look like it has been burnt off and of course programming it to move, recognize voice and learn as it interacts with people. As you can see where I am in the project just look at my Avatar photo, yes that is the Elvinator. So I would like to show you what's inside him and how to modify the Elvis and turn him into the Elvinator. This project is not finished yet but I will be adding more steps along the way. I not sure how many steps but I know there are a bunch. I am using a Basic Stamp 2 from Parallax right now for testing purposes then I'll make a board that is controlled by a PC once I get to that point.
This is the first step in transforming Elvis to "The Elvinator," an ongoing project. This first article is about opening your Elvis to reveal some of its electronics. The next article will be about removing the skin and so forth.
So, are you ready to get started?
Step 1Removing the bottom base
Support the Elvis upside down, either in an empty trash can or in your lap. If batteries are installed, you will need to remove them before beginning this step, since you could slip and make a short circuit in it. If you look at the base, you will see that there are a lot of screws to remove. Make sure not to forget about the ones in the middle of the white standoffs. See the picture below.
146 comments
1-40 of 146next »
May 21, 2011. 4:44 AMgoldenshuttle says:
please i bought this used ELVIS from EBAY; when powers on it only repositions its neck and then nothing happens. please any advise ? I tried fresh batteries and better adaptor; I also pulled all connectors between allboards and placed them back in place one by one. so far no success...Please advise me...many thanks....
Apr 28, 2012. 3:56 PMRetroPlayer says:
It is most likely a malfunctioning limit switch. There is a square plate at the base of the neck on in the inside of the torso. It slides around with the L/R, U/D of the neck. At the extremes, it closes a limit switch. One of these is not working working properly and telling the firmware that the head is in an impossible position.
When you first power up the bust, it moves the neck through the fulle range of motion to calibrate it and then set it in a nuetral position (since removing power can be done at any time and the head will just stop wherever it was.) If it is unable to sense where the neck limits are, it just hangs up.
You will need to test the switches and either replace or clean them. They may all appear to work fine, but check them with an ohm meter while holding them closed. If the value is bouncing around all over the place, then the switch is faulty (remember, this is just a switch so it should only be either 0 ohms or infinite.)
This is a common problem for the Elvis bust.
May 10, 2012. 7:27 AMgoldenshuttle says:
Checked the neck limit switches, yes one of them was leaking. But the surgery did not end there. As advised by RetroPlayer before; I removed one of the two neck motors, found that its plastic base melted in a way it is now sitting tilted.(see the pictures). This also caused one gear to break, and the slotted wheel that feeds the position optosensor is no longer sitting in place between sensor slot. later I took off the motor found that it still works, but has major damage inside due to overheating; parts of the amature shattered inside the motor.
I will try to replace the motor with something similar, and get a gear from a toy and put things together hope it works. If someone have this part for sale I will buy it....
Any idea's why the motor melted its enclosure? please educate us ....
May 5, 2012. 11:27 AMgoldenshuttle says:
BTW retroplayer; do u do WowWee regretted selling ELVIS at only 80$ ? I mean when u open it; and after reading ur hacks inside it; it is some peice of work. all that animatronics for just 80$..hwat di u think ?
May 5, 2012. 11:18 AMgoldenshuttle says:
Thanks Retro Player. I must admit that you know ELVIS bust like ur own son. I m gonna check the limit switch and report bck. God bless u man
Apr 26, 2012. 1:12 AMthomasfromla says:
It sounds like you have a burned out sensor board or possibly CPU board. Go to Robots and Androids on ebay. They sell all the boards. Or you can see if their web site "http://www.robots-and-androids.com" has instructions.
Jan 11, 2012. 7:38 PMflesh138 says:
Did you have any issues with the paint not sticking too well since the skin is silicone? Thanks!
Nov 13, 2011. 1:21 AMtelarium says:
You mention the existing Elvis Alive has a complex power board. Do you know if it uses the full 9v to control all the DC motors, or is it 5v? Specifically, the motors to tilt the head left/right and up/down.
Jul 25, 2011. 1:02 PMrobotmaker says:
NICE INSTRUCTABLE,i am looking at a different controller that works using SD84 IT HAS 84 inputs and using very cheap servo's for the servo board
servo board can get for $5 on ebay new from china,and just remove the pot and motor ,and add motor and feedback pot from ELVIS head,very easy and you free up a lot of inputs for other stuff,using microcontroller board you will many many I/O on SD84 ONLY NEED IS 7 rc inputs
ever thought of using it,also servo boards can be used with any microcontroller
SD84 has 4 on board for other servo's hands,pan and tilt and more
Jul 25, 2011. 4:55 PMrobotmaker says:
not a great idea ,mostly because of cost
what i did is buy very cheap futuba servos from china remove the pcb and pot and motor and make my own servo
servo is a controller with feedback and h-bridge plus motor and feedback pot
its very simple ,cheap and works perfect $5 total per motor and only 1 wire per servo on SD84
THEN YOU HAVE OVER 70 PORTS LEFT /IO ,SERVO AND A-D
Jul 26, 2011. 7:34 AMrobotmaker says:
another thing about using a board from a cheap servo is that the h-bridge can be parallel to have higher current or easy replace the chip with higher current h-bridge,i bought 50 to have on hand to make my own servo's from motors and feedback pot, futaba s3003 is perfect ,easy to remove parts cheap from china $5 or less and great info in seattle robotics club on the circuit
Apr 27, 2011. 10:06 PMtelarium says:
This is inspiring stuff. I'm a bit new to all of this, so forgive me if I have some newbie questions. The main thing I don't get is the ELV-09 board. I'm not clear what this board actually does and why you felt the need to replace it. Can you elaborate?
I'm interested in controlling this with an Arduino board. Have you ever looked into that? I know it can read VR data, but I'm not sure about how the neck motors will integrate...
Apr 28, 2011. 11:43 AMtelarium says:
Thanks for the response! I was considering the Arduino Mega board, which has 54 digital outs and 16 analog inputs. Would that be enough? Or do I need an input for each neck switch?
Like I said, I'm new at this. But I'm assuming that by utilizing the boards that are already inside Elvis, the digital outs on my Arduino would work to control direction of each motor and the VR can be fed through the analog input to determine positional data. Also, I assume using the existing boards means I don't have to deal with the volts as much.
Do I sound like I'm on the right track here?
Apr 28, 2011. 5:09 PMtelarium says:
Yikes, that does sound tricky. Maybe I would be better at building a new ELV-09 board as you did. But yeah, if you could provide that scan, I would be very thankful.
May 19, 2011. 10:25 PMtelarium says:
Have you had a chance to scan the bottom board to show me where I need to cut these wires?
Jun 15, 2011. 9:18 AMtelarium says:
Damn, sorry to hear that man. Don't worry about it, I think I've pretty much figured everything out. The only thing left I have to work out is how to get my Arduino microcontroller to interface with the ELV-13 board properly.
Apr 29, 2011. 9:54 AMtelarium says:
Well, the more I think about it, the more I do think building a new board as you suggested might be the way to go. But that does lead to one other question. I assume this would mean I should hook this board up to the PWM outputs on the Arduino board instead of the digital outputs, right?
Apr 16, 2011. 11:53 AMapplicationbistro says:
Trying to figure out what the requirements are for controlling all of Elvis' components I have come up with the following I/O requirements:
16 inputs (10 from VRs, 4 from neck switches, 2 from IR boards Rx)
22 outputs (10 for each motor/direction, 2 for IR boards Tx)
Have I over looked something?
Apr 17, 2011. 3:58 PMapplicationbistro says:
I appreciate all of your help!
I am eager to bring my Elvis alive. I am attempting to translate your instructable into Arduino (that's all I have right now).
Apr 16, 2011. 9:13 AMapplicationbistro says:
Looks like that is the pinout for ELV-07 not ELV-09.
Apr 15, 2011. 8:43 PMapplicationbistro says:
Have you listed which VRs (which color plug) go with which motor? I am trying to avoid taking the guts out of the face, and since i am working from behind i can't see where all of the plugs are going to.
Mar 27, 2011. 11:47 AMstardogg says:
GWJax,
I'm confused. Where are the 7 VR's? I am putting together a shopping list for this project, but I don't know if I need to supply my own VR's or if they are already in Elvis...
This is an awesome Instructable!
Mar 27, 2011. 12:16 PMstardogg says:
I am anxiously waiting for the face movement step...
Nov 7, 2010. 9:32 PMMister Jellyfish says:
I did it! Thanks, Jax, for the great walk through. My daughter and I kept alternating between different sized small screwdrivers that fit the different contours. You were right about the chest being hard to get off. We just kept pulling and wiping the screwdrivers gently across the glue jams and they slowly relented.
Aug 23, 2010. 12:22 AMdawsonj says:
that was scary...
Jun 12, 2010. 8:58 AMrobotmaker says:
hi jwjax love your project,cant wait to take my elvis apart and add it to my AI animated robot design keep up the good work,it shame i cant get on trossen my robot will win top prize with great mods i made also my johhny five projects is getting really good too ,both with AI SOFTWARE after both done working on full detail full size johnny five
Mar 4, 2010. 9:27 AMMiriadaTheCarrot says:
Slightly disturbing, this.
Something between Terminator at the very end of the first film and a Barbie doll, i think it's the pink that hints "Barbie".
Jun 11, 2009. 8:32 PMtwocvbloke says:
This is just sooooo creepy, not just the remodelling, but the actual device itself, but I suppose it's one step closer to actual androids, but still, creepy... :S Great job though... :D
1-40 of 146next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:GWJax
I love to make and hack into robots and make them do things that they are not designed for. Also I enjoy programming in PBasic for the Parallax Basic Stamps, I enjoy reading electronics books and I ma...
more »
