Step 37Mixing the mold putty
iImage Information
OK before we are ready for mixing the mold compound, make sure you cote both the inside of the mold frame and the surface you are working on and your Elvis eye with your mold release. Lets mix the putty, now that we are ready. Take 4 grams of part A and Part B of the amazing mold putty. Flatten each part out with your hands into a pancake. After you have done this place the 2 together and mix by hand until you have an even color, but don't mix too long else the putty will start to harden and you'll have to start over. Once you have it mixed place it into the frame and press it in flat and fill in the corners of the mold frame. Now its time to place the eye into the center of the putty, Press the eye in the center of the putty until you reach the edge of the eye but do not press it until you hit the bottom of the surface you are working on make sure that you have at least 1/8" of space at the bottom of the eye and the surface of the mold. If you make this frame exactly as I did and weigh out your putty you will not have to worry about hitting the bottom. Note if you hit the bottom of the surface START OVER and add more putty!
