Step 54Jaw piston
Now we are going to make and add the jaw piston, I know that there are two jaw pistons but with out cutting down the main face and rebuilding it up we will just install one. Plus the design I have on the skin would just cover it up anyways so not harm done.
Making the Jaw piston is quite easy the following supplies are as follows:
1. 1ea 35mm 5/32" brass or copper tube
2. 1ea 60mm 1/8" copper or brass tube
3. 1ea 10mm 5/32" brass or copper tube
4. 5ea #4 washer
5. solder and flux
6. Flame torch
First cut you tubes to length, once done solder one washer to the 35mm 5/32" tube at the end. Then take the 60mm tube and solder the 10mm tube to one of the ends. After this is soldered take a washer and at a 45 deg angle solder this to the 10mm tube. Your piston is now complete. Sand or file down any large solder bumps. Also use a vise or a third hand devise when soldering with a torch, a standard soldering iron will not solder these tubes together. Once everything is soldered insert the 1/8" tube into the 5/32" tube and trial fit the motion. If it is tight the sand down the 1/8" tube down a bit until you have a good fit. See photos below as a reference.
Add Comment
