Step 7Removing the skin
Now, it's time to remove the skin. This part is one of the most time consuming steps. First, DO NOT use a razor blade. Instead, use the small flat blade screwdriver. This will prevent any slipups; you could potentially cut the robot skin in half. We'll start by removing the wig. The wig is hot-glued to the head until the point where it reaches the skin then it is sewn on. From the back, simply pull up on the wig all the way to the skin on both sides.
Add Comment
