When I first saw Chan Luu wrap bracelets, I was pretty excited.  Until I saw the price tag ($200+)!
These bracelets are great since they look like bangles but are much more comfortable.  Because it is so long, it has a certain amount of flexibility to be worn as a necklace or anklet as well.  It was very simple to make, and mine cost less than $15 in supplies and only took a few hours.  The color combinations are endless - have fun with it!
Step 1: Supplies
All you need for this bracelet is:
Leather cord (or any sturdy, thin cord): First figure out how many wraps you want to make.  Measure that distance, double it, and add around 4' extra for the loops at the end.  I found that four wraps on my wrist perfectly matched three wraps on my ankle, whereas five wraps on my wrist didn't work as an anklet.  I needed roughly 2 yards.
Beads: I used 4mm faceted czech glass beads.  This online vendor seems to have a good selection, but any bead store would have these, and of course any type of bead will work!  Similar bracelets I've seen use smaller beads than this, closer to 3mm.
Nylon thread
Beading needle: traditional or a separated eye style depending on the thickness of your nylon thread and size of beads.
Button: the kind with a loop in back vs holes works best.
veruca_salt890 says: Mar 12, 2013. 7:14 AM
These are so pretty! Can't wait to try.
jenliedkie says: Oct 18, 2012. 8:02 AM
I make these as well....found these two things reall\y helped:
1. try using two needles...one on each end..makes it easy to keep the tension even
2. I use a piece of styrofioam as a base and use pins to hold the bracelet still while you are working on it. you can move the bracelet up as you progress. put the bins in the space between the cord and the beads.
they go quick and they are great to make !
Natalina (author) says: Oct 19, 2012. 11:06 AM
Awesome, thanks for the tips!
xie says: Oct 19, 2012. 7:18 AM
I'm excited to make this! Roughly about how many beads did you need for your bracelet? I'm trying to determine how many to order. Thanks!
Hi xie!
I measured the beads at the store and did the math from there. The 4mm oblong ones I bought are about 1/8" wide, and I made my bracelet around 30", so I bought 240 and ended up using less than that. I would first determine the total length you need (depending on how many wraps you want and the size of your wrist) and see if you can determine the rough width of the beads you are ordering from the website, and go from there!
Bev Kirk says: Oct 18, 2012. 9:27 PM
Thank you for this awesome 'ible! Your directions and pictures are very clear and understandable. I can't wait to get some started next week with some of my students! Great job - keep 'em comin'!
MKosterich says: Oct 18, 2012. 4:55 PM
Gorgeous! I need to make myself one of these.
momm says: Oct 18, 2012. 7:32 AM
so simple but sooo lovely thank you for sharing (loving the polish too)
branchym says: Oct 18, 2012. 7:18 AM
This is cool I will try this with my older students
Karinsart says: Oct 18, 2012. 6:53 AM
Really clear and well done instructions. I'm looking forward to making these for my nieces, because as you mentioned, that price tag was shocking! Thanks for this Instructable!
Pixie Puddle says: Oct 8, 2012. 2:29 PM
I have got to try this really simple and I love the final look, this is added to my list of things to make for sure, :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
