3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wraparound Desk Made From One Sheet of Plywood, 2 Filing Cabinets
Five years ago I wanted a desk. When I was a kid my mother made a desk out of an interior door and two filing cabinets. I already had one filing cabinet about 29 inches tall, so I bought another the same height and tried the desk out.
It blew.
It was ugly, tended to slide by itself, I hit my hip on the corners occasionally, and I heard disconcerting cracks and creaks when I put my 20" CRT in the middle where I wanted it. So I thought again.
My specifications were, in order of importance:
1) Elegant - I liked desks that wrapped around you
2) Easy to Make - Minimize tools and time
3) Cheap - Ideally made out of one piece of plywood.
4) Movable - I 've moved too many times to set myself up with a cumbersome desk.
I like corner desks as a rule, so I drew up a design with 6' legs from a corner, with a couple of curves. 6' on a side was a good size not just aesthetically, but because with judicious cutting I could cut all the structural pieces out of one piece of good, double-sided plywood. In my book, elegance of design is something you enjoy long after you've forgotten the monetary cost.
This project took an morning for the woodwork, plus the rest of the weekend for staining and poly coats.
Caveat maker: I have no in-progress photos of this project as I made it 5 years ago. I've done my best to provide as clear instructions and drawings as I can. If you are unclear about any step, leave me a comment and I'll try to explain better.
(Please rate this project by hitting the (+) or (-) buttons near the upper right of the page)
Step 1Gather Materials and Tools
Materials:
Two (2) short filing cabinets of equal height
One (1) 4'x8' piece of 3/4" double-faced plywood. Just make sure both sides are pleasing to the eye, since you will have to flip one half over to marry it with the other.
One or two (1-2) table/trunk/whateveryoucallem-latches. You know the kind---two pieces, one with a loop and a level thing to grab onto the other side. (see picture below)
Four pieces of 1/2" radius quarter round trim, 18" long.
Metal strapping or corner brace for extra support in the center. I used a corner brace because I had one handy, but a straight bracket would make more sense.
Paint or stain plus polyurethane for finishing
Optional:
~12 feet of real wood edging with heat-sensitive glue on back.
Tools:
Jigsaw
Screwdriver
Optional: circular saw and long straightedge
Optional: Clothes Iron or possibly curling iron
Sandpaper of varied grits
Paint brush/drop cloth
50 comments
1-40 of 50next »
Nov 29, 2011. 11:07 AMThe ironman says:
you could add chaulk paint to make to ultifunctial
Jun 24, 2011. 3:49 PMtinker234 says:
hey metal table top
Jun 9, 2011. 1:52 PMmroca1 says:
good work :D
Jun 3, 2011. 12:33 PMtinker234 says:
love the idea i might just use stronger legs in fear of my legs but for you it is perfect
Mar 28, 2009. 12:13 PMBlackHatCracker says:
I like it! Just in need of a switchable power strip, and a few holes with gromlets to run the wires through... and a cable organizer to keep all the cables together... Love it!!
Sep 4, 2010. 7:02 PMwhisperonthewind says:
Cable organizer? Three words... velcro strip ties.
Sep 5, 2010. 2:37 PMBlackHatCracker says:
lol.. ok that works too...
Sep 4, 2010. 7:00 PMwhisperonthewind says:
Word of caution: Depending on your own height, the two filing cabinets could be just a little too high. I am currently using a slab of countertop and two filing cabinets as a computer desk, and I really like the countertop - no more mouse pad! But when my computer chair is high enough for the desktop, my toes are stretching to reach the floor. When my feet are on the floor, I find myself typing with my shoulders hunched up because of the height of the desktop. You may not have a problem - my height is 5' 3" - but you might want to measure the height of your current desk, then calculate the total height your new creation will be. You'd never know how important an inch or two will be until you're stretching your toes or hunching your shoulders. I'm currently designing a pvc pipe shelving base for under my countertop, with the filing cabinets being relegated to the sides of the desk again. In the meantime, I'm just stretching and hunching, depending on my mood.
Jun 19, 2009. 12:01 PMnatharious says:
Any idea where I could get cheap filing cabinets or an alternative? I'd love to create a similar desk.
Aug 15, 2010. 8:46 AMjag217 says:
Milk Crates
Mar 28, 2009. 12:18 PMBlackHatCracker says:
I have a question.. How much space is a metric buttload?? lol...
Jan 31, 2008. 3:34 AMjolebitte says:
Finally, I'm done with my desk!
The hardest parts were to get the halves to match (thick sheet, a bit shallow circle-saw) and the painting.
http://www.instructables.com/id/Swedish-Wraparound-Desk-Made-From-One-Sheet-of-Pl/
Mar 8, 2009. 5:27 AMmyohmy says:
Your colours look very sophisticated. Love the grey and white. Well done!
Mar 8, 2009. 5:25 AMmyohmy says:
This is brilliant!! I'm thinking more filing cabinets could be added and the desk top extended if a person needed more cabinets too. Well done!! I've been thinking of converting s closet into s tiny work station. This would be perfect!! :0) !
Jan 8, 2009. 12:56 PMReCreate says:
since computers are metal on the outside they can survive some fires probably some of the outer plastics may be ruined
Jan 31, 2008. 8:05 AMMaffu says:
That's a simple but brilliant idea.
At around the time you were building this I paid around £200 (in a sale, no less) for a flatpack . corner unit
Ok, so mine has a slidey keyboard shelf and a monitor riser on it, but I prefer yours and I'm thinking that I may have to do one just for the sheer joy of having made it.
Genius.
Apr 19, 2008. 6:48 AMMaffu says:
Opps - fixed the link now.
Jan 31, 2008. 7:09 AMMak5 says:
Props... I like the idea of nomadic furniture, I'm about to move AGAIN. I'm thinking desk, bed and shelves using this method. Again, props.
Oct 18, 2007. 4:03 PMjend5570 says:
I love it!! but umm......where do you keep ur clothes?
Jan 31, 2008. 5:05 AMclark says:
haha...what?
Nov 26, 2007. 2:53 AMramroids55 says:
Most People Dont Keep Clothes In A File Cabinet
May 24, 2009. 3:56 PMmcflyalright says:
my clothes are actually in a file cabinet.
Nov 7, 2010. 1:06 PMKnuxz says:
Lol. Could probably get rid of what doesn't fit me and do the same!
Oct 7, 2007. 3:09 PMchalky says:
nice shape i like it brilliant.
Sep 17, 2007. 8:24 PMJouda Mann says:
Truly an elegant and easy alternative to the "disposable" furniture found at mega stores. Bravo!
Jul 31, 2007. 11:35 AMcopycatfilms says:
this is a perfect way to make a corner desk! love it!! I just wish I had a truck to carry big pieces home now! :) Thanks!
Jul 14, 2007. 6:57 PMn0klu says:
Here is a top from 1 cut 4'x8' sheet 3/4" ply sitting atop 2 Wal-Mart wooden file cabs and a spare sheet of Ply for the power distribution / third leg.... (has my 20" monitor on top and slide out keyboard shelf under the mid section)
Jul 27, 2007. 5:01 PMn0klu says:
Here is the measurements and 1 sheet layout....
Jul 14, 2007. 7:15 PMn0klu says:
Some more views of it...
Aug 22, 2010. 9:33 AMdejure says:
For any of these designs, you can add a 3/4" x 1-1/2" board around the back side. This has the effect of adding 1-1/2" of thickness, for support. They do this on high end shelving to stop them from bowing under weight. If you have to join two pieces and want their surfaces to remain flush with each, you can cut a 1/8" kerf down the center of the joining edges, then install a spline, which is just a piece of wood which just fits into the kerf and sticks out enough to go into the opposite kerf. You can cut the kerf with a router and bit, a biscuit machine, or a circular saw (after you clamp a couple pieces of wood to support and guide the saw. This could also be done with dowels with the one end rounded over (similar to what kitchen tables use). In either instance, careful marking and cutting is worth the effort.
Mar 19, 2009. 1:02 PMGeekyAdam says:
nice. i like the little extra shelf on the left as well.
Jun 6, 2007. 10:33 AMblakelock says:
much better than my blockity-block version. nice design.
May 9, 2007. 4:00 PMMD_Willington says:
Awesome, and the materials are way better than anything you'll find at the big box stores... real wood as opposed to sawdust + glue...
May 1, 2007. 7:35 PMOffice Viking says:
Nice project! I love custom-building things around the house. It makes way more sense than paying a ton of money for a store-bought piece that's locked into a certain size. I'm diggin' your jigsaw cutting work. Smooth. I've had good experiences with applying an acrylic finish to wooden top surfaces. It makes it completely waterproof and provides a shiny appearance.
Apr 30, 2007. 4:29 PMChris Tucker says:
Excellent design! VERY reminescent of the classic "Nomadic Furniture" DIY books. And such economy. Almost no wasted plywood. For myself, I think I'd build shelving in place of the file cabinets. If for no other reason than to have the LaserWriter right at hand and yet out of the way. Hmmm. Mounting the scanner on a sliding platform in the shelves on the other side would also work to keep it handy and yet not in the way. Off to SketchUp! I have some designing to do! Thanks for the inspiration!
Apr 30, 2007. 4:22 PMChris Tucker says:
Add a PowerSquid and a shelf for all the wall wart adaptors. (I'm currently at 6 adaptors and likely there'll one or two more in the future.
1-40 of 50next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:themostbob
