Wrappers Made Umbrella
Published
Introduction: Wrappers Made Umbrella
We used an old umbrella and the wrappers of snakes to make this.
Step 1: EAT
Enjoy your snacks before you get started.
Step 2: GATHER THE RAPPINGS
Gather the wrappers.
Step 3: WASH THE WRAPPERS
Wash them with soap so that no oil will be remained.
Step 4: REMOVE THE CANOPY
As to the umbrella, cut and removed its canopy.
Canopy is a part of umbrella, which cover the whole ribs.
Step 5: MAKE a MODEL OF THE REMOVED CANOPY
After removing canopy, we cut and separated it to a small unit.
Step 6: DESIGN
This unit was used for designing wrappers in terms of size, and in addition we considered how the wrappers are placed.
Step 7: TAPE THE WRAPPERS THAT ARE THE SAME COLOURS
After carefully cutting the glued areas of the snack packets to make one flat sheet, use sellotape to tape the ends of few sheets together to create one big sheet This should be big enough to cut out a segment of the umbrella.
Step 8: CUT OUT THE GLUED WRAPPERS INTO SEGMENTS USING THE MODEL
Once the taping has finished, use pen and the model that you cut out at (5) to draw the outlines of the model onto the big sheet. Make sure to draw on the inside part of the sheet in order to make it look neat. Then cut out the segment. Repeat 7 and 8 and make as many segments as you like for your umbrella.
Step 9: FIT THE SEGMENTS
After cutting all the segments needed, open the canopy removed umbrella and make two ribs about 60 degrees. Then put the segments on the ribs, simply fit the sides onto the ribs using tape.
Step 10: FIX THE NEW CANOPY
10.
When all segments are fit, carefully tape them up from subsurface untill there's no aperture in this new canopy, check it as well as you can because it's important for an umbrella to be waterproof.
And after all these steps you can get an umbrella.
    • BBQ Showdown Challenge
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    2 Discussions
    Awesome! I've enjoyed the packaging of Japanese foods and now thanks to you, I can make something from it too!
    Great idea. You can have a one of a kind personalized umbrella that you can always recognize.
