3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wrist and ankle weights
Every time I start weight training I get distracted. Okay, I admit it, I'm lazy. I can see the benefits of weight training in other people but lean muscles are just something that is not a priority for me. The only reason I want to increase my muscle mass, especially in my arms, is that I sit and work at the computer all day.
A friend encouraged me to get started by lending me an old pair of wrist weights with half the black sand missing. After about a week I saw how they might help but I needed a better pair where the sand would not leak out. I tried to repair them but finally gave up and started from scratch.
Here then is an easy way to make your own wrist and ankle weights. After you have the materials it only takes a few minutes to put them together.
They are super comfortable too, unlike the fabric, sand filled weights. They are so comfortable in fact, I can wear them when I go to sleep and even when I take a shower.
Step 1Materials and tools
materials and tools
The materials are straight forward.
First you'll need an old bicycle tube.
Second you'll need two 1 lb packages of 2oz sinker weights.
Third you'll need a package of heavy duty snaps.
Forth, some synthetic (nylon) diamond braid twine
So are the tools
First , a pair of shears.
Second, a small tack hammer.
12 comments
Jul 24, 2011. 8:36 PMSIRJAMES09 says:
for a more finished look, fold the cut ends inward & install the snaps so that it locks everything in place. :)
Jul 24, 2011. 8:34 PMSIRJAMES09 says:
HEY LISTEN UP PEOPLE!!
I have a set of ankle weights(5 pounds total) that I do not use & do not see me EVER using....
If you want them, send me a PM with your name & address and I'll send them to you FOC(free of charge).
Donations will be gladly accepted tho not required.
Feb 23, 2009. 3:15 PMCompGeek812 says:
Any idea what kind of weights should be used if you want to make a 20lb ankle weight without making 20 individual pieces? I'm not sure those little sinker weights would do the trick unless I filled up the tube and wrapped it around several times (which may be what I have to do anyway :) ).
May 6, 2009. 10:07 AMbrendan945 says:
Be careful with really heavy ankle weights. You can start by irritating, and if continued, later tearing your ligaments and tendons in your knee. Same with elbows. You can check around, but I think 20lbs is way too much.
Nov 14, 2010. 2:12 PMVisit_Homemadegymstuff says:
...not to mention RSI and the little known fact that running/jogging with wrist/ankle weights actually trains you to run SLOWER! (similar to running on sand)
Apr 20, 2009. 6:41 AMYerboogieman says:
A heavier metal.
Aug 15, 2009. 11:14 AMjarjar761 says:
it may be alil cheaper to go buy some depends on how much they
Aug 11, 2010. 7:42 PMgeoslim13 says:
about $10 -$20 but these are actually smaller heavier and stronger
Jun 1, 2009. 8:38 PMeyebot117 says:
I've got a set of these. I do push ups with them. When I'm off the ground, I push my body off of the ground, clap once or twice, and try to land my hands where I started. Then I go down, and repeat. Does wonders for your handspeed. Now, every time anyone plays "red hands" with me, I always win!!!
Oct 28, 2008. 12:32 PM8bit says:
Great Idea! I've been needing something like this!
Nov 3, 2008. 11:39 AM8bit says:
OK thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
62
Author:watermelon
I'm an Emu. As a young chick my parents use to feed me watermelon and I loved it so much everyone nick named me, you guessed it, watermelon. Now that I have moved away from home I rarely get to eat an...
more »
