Writing on Plastic
Introduction: Writing on Plastic
Have you ever needed to write on plastic and the ink didn't stick even when you used permanent marker. Well I work in a company that prints on plastic all the time. We prepare the plastic to get the ink to stick by oxidizing the surface first. In short we pass the plastic past a flame that lightly "burns" it. But not enough to see a discoloration.
Step 1: Writing With a Marker
So you want to write something. Try writing on plain plastic.
Step 2: Ink Comes Off
Rubbing a finger across the ink causes it to come off.
Step 3: Oxidize Surface
Use a candle or in some cases a small propane torch. Quickly move back and forth so the plastic doesn't melt or get discolored.
Step 4: Mark the Surface
Mark on the area you flame treated.
Step 5: Rub the Ink
Rub on the area with marker and flame treated. It should resist coming off.
Step 6: Candle May Cause Soot
A candle may cause a soot mark like the one in the picture. Using a small propane torch instead of a candle might avoid this.
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    How long dos the heating effect hold good. Can I write on it after few days or months.
    I was curious about what would happen if I put a clear coat of nail polish on top (mine happens to be vegan and non-toxic, and if so whether or not it eliminates the need to set the marker with flame first.
    Exactly what I was looking for. Thanks.
    it also works if you roughen the spot you are going to write on with sandpaper or an Emory board, etc.
