X-10 Key Chain Remote Station
222
Posted
Introduction: X-10 Key Chain Remote Station
This instructible is in response to my placing my X-10 key chain remote in the basket by the door, and having to fumble for it among all the other items, glasses, keys, do rags, etc, I had in the basket when I came home. Now my X-10 key chain remote is beside the light switch so I can turn on four lights the moment I walk into the house. This is a two part 3D print so that it can be used with either a left or right side mount with the same 3D print.
Step 1: Two Stl Files
Print these two files. As you will discover the two parts will need to be mounted together with a couple of screws, but because of their properties, can be used to the left or right of any light switch plate. Now your X-10 key chain remote will always be within reach of the same light switch that controls your ceiling fan, which has no use if you leave your fan on when your not home. Your switch location is now useful again. My last three houses had this. If I left my ceiling fan running, I had to walk across the room to turn a light on in my house.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    4 Comments
    Excellent. I have a rock-solid x10 system and I love these little keychain remotes. I leave them scattered throughout the house for convenience. I'm going to print about 5 of these! Amazing!
    If you saw my last comment about being disappointed that X-10 was 1-2-3-4, well My batteries just went too low to control the light, and I read the notes. Turns out the X-10 key chain remote is programable for whatever you wish. I have done so and will 3D print another section to add beside my light switch to control the rest of my lighting.
    Yeah, you can set them to start at any house code and unit code, the same for the smaller keyfob sized version of the X10 mini remotes. I can't recall it's exact model number. I prefer the version you're using, which is thinner and laid out vertically.
    Thanks so much for the comment. I also designed a wall holster for the large controller, but haven't discovered the need to hang it yet. RCA used to make the same frequency controllers. Their key-chain remote was only two channels, but had a switch inside to choose 1-2 or-3-4. I wish X-10 key-chain remotes were switchable from 1-4 to 5-8. Again, thank you.
