Introduction: X-2812B Test
Picture of X-2812B Test
X-2812b has 4 ws2812b RGB LEDs. You can have a look at this video first.
https://youtu.be/ApgWs4l2y_U
Step 1: X-project Member
Picture of X-project Member
Step 2: Test Code
Picture of Test Code
Library
https://github.com/adafruit/Adafruit_NeoPixel
Code example
https://github.com/lspoplove/D-duino/blob/master/X-Project/ws2812/ws2812b.ino
There is a dial switch which you can adjust D3~D10 to control ws2812.
Do not forget dial number 1 to the right side.
IgorF36 (author)2017-06-27
I switched on the D3 and used the code example above on a D-Duino-32 (with, obviously, an X2812B on top) but the four pixels still remain white.
Where I'm wrong?
kd8bxp (author)IgorF362017-10-11
Use the GPIO number (I think it's 0 zero) - I had a similar issue. There is some timing issue with the display and the neo-pixels when using the D-Duino32. That issue doesn't seem to be there with the D-Duino ESP8266. Here is my instructable if you are interested.
https://www.instructables.com/id/ESP32X-Project-Cheerlight-Badge-Using-MQTT/
About This Instructable
314views
0favorites
License:
More by lspoplove:How to Attack WiFi by Pocket 8266Pocket 8266 --ESP8266+18650 Battery(DHT to Thing Speak Project)Make a WiFi Necklace
Add instructable to:
