Perhaps you have never been gifted at drawing, or you don’t have the time to do it yourself, so why not let a simple x-y plotter draw for you. This simple two axis device can accurately moves a pen to draw out anything.
The Device:
The x-y plotter has a two axis control and a special mechanism to raise and lower the pen. The plotter has a hole in its base where the pen goes through. It was designed to print on both paper or any surface such as a wall; simply place the plotter against the surface and the pen will draw away through the hole. Each axis is powered using a single stepper motor and belt. Pen control is achieved using a servo. All electronics are controlled by an Arduino and powered by a 12 volt wall adaptor.
A Demo Video
This video shows a demo of one axis (y-axis) of the plotter moving back and forth. The x-axis was moved by hand to generate curves.
The Team:
This project was completed by Tommaso Buvoli, Kristina Callaghan, Bruce Deakyne, and Phillip Dunlap for CU Boulder Things that Think Spring 2011.
Remove these ads by
Signing UpStep 1: Materials
- A Laser Cutter capable of cutting pieces up to 18” long.
- Band Saw
- Drill Press
- Screwdriver
Raw Materials:
- Several sheets of 1/4 inch thick acrylic (One side must be at least 18”).
- A small sheet of 1/8 basswood
- Several 1/4 inch dowels (metal or wood - at least 18”)
- 14 small long bolts and nuts
- 28 washers
Electronics
- 2 Gear & Belt combo sets: http://www.goldmine-elec-products.com/prodinfo.asp?number=G15973
- 2 high torque stepper motors: http://www.goldmine-elec-products.com/prodinfo.asp?number=G18202
- 2 stepper motor drivers (ULN2003A)
- 1 breadboard
- 1 2.5v, high current supply
- 1 5v supply (for arduino, USB cable acceptable)
- 1 EasyDriver Stepper Motor Driver (http://www.sparkfun.com/products/10267)
Visit Our Store »
Go Pro Today »
My contact email is danielffonsi@hotmail.com
grateful for the attention
http://www.thingiverse.com/thing:17631
Your project is basically a very much improved version of the old pantograph and "tracers" used for drawing as well as router work. What you have built could easily (?) be modified to operate larger units in order to produce...
Like al of the others I commend you for your efforts. Truly a job well done!!
Also perhaps substituting larger dowels - like 1/2" or greater - for less flex might help. Nice 'ible! 3/5 stars.
@nutsandbolts_64 and @Unclegummers -- The pen-on-servo trick works surprisingly well in the egg-bot, which is where I'd guess they got the idea.
Good start for maybe eventually attaching a drill or something to it and creating a CNC machine ;)
