3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
X Y speaker laser-show
Here I will show how to make a audio lasershow. First I have two videos for you.
I have accomplished with laser show program for mac(is also possible with a frequency generator program)and music cool effects.
The vibrations from the 2 base speakers (with 1 mirror an each speaker) makes the laserbeam move with the music and the frequencies (audio).
Step 1What you need
Hotgluepistole
laser
2x base speaker
2x mirrores (1,5cm X 1,5cm)
an borde (wood)
straw
2x plastic pices(1mm thick)
wooden stix (p.ex. "mikado stix")
styropohr
19 comments
Nov 12, 2011. 10:35 PMjansell says:
Can somebody provide an english translation of this article?
many thanks
the internet.
Mar 6, 2011. 9:24 PMjmanc2 says:
Wow, this project reminds me of the laser show I built and put on for my high school dance, 22 years ago lol. I made my mirror/actuators almost the exact same way (glue, toothpicks, scavenged front surface mirrors and speakers) then fed either sound from a signal generator or actual music to the speakers for different effects. I built the whole thing in a rack mount carcass for portability. The laser was a portable HeNe from Edmonds Scientific that measured about 2x3x8 inches and had less power than the cheapest pen lasers today. This brings back memories!
Apr 20, 2008. 10:58 AMShadetree Engineer says:
Nice idea for getting a pair of mirrors to move. I was lucky to find an old laser video disc player, and built a light show module using the aiming mirrors, which are directly connected to the speaker outputs of a small amplifier. The coils on each mirror were close to four ohms each, and took less than five watts to drive. Next time I fire up my module, I'll be bouncing it off of two mirrors to get a larger pattern as it plays about one foot diameter at a five foot range. I never did figure out how to get that video disc laser tube to turn on though...bummer.
Jul 26, 2008. 7:01 PMnatepost says:
stupid question...but What exactly is a laser video disc player... i have never heard of one of these... don't know why i might just call it something else i guess...and what do they look like it sounds interesting.
Jul 27, 2008. 9:27 AMShadetree Engineer says:
The reason todays cd's are called 'compact disc', because optical disk's used to be huge! Wiki
And the laser used in one of these old machines was just as impressive. The one I have salvaged is a CO2 tube with a high-voltage power supply. I just never was able to figure out how to get the supply to turn on...
Aug 11, 2008. 3:42 PMGridnack572 says:
make sure this CO2 tube is intact and still holding co2 i could be wrong but i believe their the same (CO2 - vacuum tube) if its not holding what its supposed to vacuum or co2 it wont work at all
Aug 14, 2008. 10:33 PMShadetree Engineer says:
I don't think it's a vacuum tube if it's been filled with CO2, wouldn't a vacuum require the removal of any CO2 present? The tube I have is intact as far as I can tell. No cracks or obvious signs of deterioration. But I don't think I'm ever going to use it, so it's just a shop trophy.
Aug 22, 2008. 3:48 PMalexhalford says:
CO2 laser tubes do contain CO2 but at less than atmospheric pressure, so they can be (if slightly inaccurately) as containing a vacuum.
Aug 31, 2008. 11:55 AMShadetree Engineer says:
Okay, my mistake. I had thought that all gases have to be removed to have a vacuum, and didn't think of variable amounts of a vacuum.
Aug 31, 2008. 2:27 PMalexhalford says:
A 'soft' vacuum is slightly lower than atmospheric pressure (14 psi). An area of extremely low pressure is know as a 'hard' vacuum. You are correct, but a 'true' or 'perfect' vacuum is impossible to generate on earth... AlexHalford
Feb 20, 2009. 2:54 PMhg341 says:
well you must live down low but where i live the atmospheris pressure is near 8-10 psi i think
Sep 3, 2008. 9:46 AMShadetree Engineer says:
Aww darn! Another one of those absolutely perfect things that is never present when you finally get it right!
Oct 2, 2008. 6:18 PMteam_nes_1986 says:
Watching the second video is like watching the beginning of the music video for "Vital Signs" by Rush. Pretty cool, man.
Apr 26, 2008. 10:40 AMDerin says:
please correct grammar other than that nice ible
Mar 22, 2008. 7:59 PMPoppa Chubby says:
Very cool idea. How do you aim the laser so it hits both mirrors? Was it trial and error, or did you have a method? I wonder if you could get a larger pattern by gluing long sticks to the diaphragm and positioning the mirrors farther out? Kind of like cantilevering them... I might have to try this at home.
Feb 17, 2008. 3:03 PMnf119 says:
I made the exact same thing! I guess you beat me to it.
For all you Windows lovers here is the standalone program I used: lissajous.exe
Dec 18, 2007. 1:06 AMHeWantsRevenge says:
fun fun +1
Dec 17, 2007. 3:07 PMGorillazMiko says:
very cool instructable, great pictures too.
Dec 17, 2007. 12:28 PMhomunkoloss says:
Cool Effects ! I tried this with 1 Speaker. But how is the sound quality ?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:funky alex
