Introduction: X415 K'nexterminator Machine Gun
Picture of X415 K'nexterminator Machine Gun
This is possibly the first detailed Knex machine gun here. this gun is pretty powerful, firing at a good 1100 RPM, depending on what motor you use.
Pieces
x=# of chainlinks
Rubberbands: x+2
One-slot connectors(gray):4x+1
White rods: x+47
Yellow rods: x+23
Blue rods: x+31
Orange 2-slot connectors: 4x+40
Chainlinks: x
Gray rods: 21
Wire/string: 16"
White connectors: 23
Yellow 5-Slot Connectors: 16
Green 4-Slot Connectors: 27
Green Rods: 58
Red 3-Slot Connectors:36
Silver Spacers: 66
Blue Spacers: 20
Red Rods: 10
Motors: 1
Red Gears: 3
Gold Gears: 1
Blue 7-Slot 3D Connectors: 18
Purple 4-Slot 3D Connectors: 4
Tabbed Brown Connectors: 5
Total: 452 Pieces!!
Step 1: Chain Links
Picture of Chain Links
These are the basic "barrels". Make as many as desired
Pieces:
1 rubberband
4 One-slot connectors(gray)
1 white rod
1 Yellow rod
1 blue rod
4 orange 2-slot connectors
1 chainlink
Step 2: Build the First Front Piece
Picture of Build the First Front Piece
The first frontish piece
Build 5 gray rods connected to white rods (pics 2+3)
Pieces:
5 Gray rods
5 Orange 2-Slot connectors
5 white rods
2 blue rods
2 yellow rods
1 Yellow/Gray 5-Slot connector
2 Green 4-Slot connectors
Step 3: Build the Second Front Piece
Picture of Build the Second Front Piece
The second frontish piece
Slightly more difficult
Pieces:
4 orange connectors
1 blue 3d connector
1 purple 3d connector
2 Yellow rods
1 commando connector (wierd black piece)
2 Red rods
2 Yellow/orange connectors
1 Blue Rod
6 green rods
2 Red/Granite connectors
3 White rods
Step 4: Build Gear One
Picture of Build Gear One
A complex gear.
Parts:
15 Silver Spacers
2 Commando connectors (wierd black things)
3 tabbed Brown connectors
3 Blue spacers
3 red gears
1 Orange 2-Slot Connector
2 Gray 2-slot connectors
2 red rods
1 Yellow rod
2 white 8-slot connectors
4 green rods
3 white rods
1 gray 1-slot connector
Step 5: Assemble
Picture of Assemble
You should now have 3 parts... 2 front and 1 gear
Step 6: The Trigger Handle
Picture of The Trigger Handle
This is the part in the back
Pieces:
21 Red 3-slot connectors
12 Blue 3D connectors
13 White Rods
9 Blue rods
7 yellow rods
4 orange connectors
2 Yellow connectors
12 Green connectors
4 Silver spacers
8 blue spacers
Step 7: The Auxillary Handle
Picture of The Auxillary Handle
This is the front handle
Parts:
8 yellow rods
7 Red Connectors
4 Yellow connectors
6 Blue Rods
8 white rods
5 green connectors
Step 8: Build Gear Two
Picture of Build Gear Two
This is a simpler gear
Pieces:
4 White 8-slot connectors
1 motor, Large
7 Silver spacers
14 green rods
1 Gold gear
2 tabbed brown connectors
2 blue spacers
2 Gray 1-slot connectors
Step 9: Build the Bar Thingies
Picture of Build the Bar Thingies
Build these two.
Pieces:
2 White 8-slot connectors
2 Orange 2-slot connectors
2 Yellow 5-slot connectors
4 blue rods
4 silver spacers
Step 10: Build the Middle Connector
Picture of Build the Middle Connector
A thing in the middle
Pieces:
5 White 8-slot connectors
2 blue rods
2 blue 3D connectors
1 Green 4-slot connector
2 white rods
1 purple 3D Connector
7 Green rods
Step 11: Assemble Again
Picture of Assemble Again
Now you should have some parts...
Get the first assembled part, The two bar thingies, and the front connector
Step 12: Build Two Pieces
Picture of Build Two Pieces
Build the first and second things
Parts:
3 grey rods
1 White 8-slot connector
3 orange 2-slot connectors
1 white rod
3 green rods
Step 13: Build the Block Mechanism
Picture of Build the Block Mechanism
This will stop the motor from spinning.
Pieces:
29 Silver spacers
3 blue connectors
7 blue spacers
10 orange 2-slot connectors
5 white connectors
1 red rod
1 yellow rod
1 rubber band
Step 14: Build and Attach the Bottom of the Aux. Handle
Picture of Build and Attach the Bottom of the Aux. Handle
Parts:
4 Gray rods
5 Green connectors
3 Yellow rods
1 blue rod
3 orange connectors
2 yellow connectors
3 green rods
2 blue 3d connectors
2 purple 3d connectors
Step 15: More Attaching
Picture of More Attaching
Attach the block mechanism and the thingy made in step 12
Then Attach gear 2
Step 16: The Block Mechanism to Trigger Connector
Picture of The Block Mechanism to Trigger Connector
You'll build a part now
Nevermind the wire yet
Keep the hinge to the side now.
Pieces:
5 Blue Rods
1 red rod
1 Gray rod
7 Orange Connectors
1 Green connector
4 Red 3-slot connectors
3 yellow connectors
8 green rods
1 Green connector
3 silver spacers
1 Yellow rod
1 Hinge(blue and black)
1 white rod
Step 17: Build More Stuff
Picture of Build More Stuff
more things to build
keep the first thing to the side
Same with the second
Pieces:
2 Grey rods
1 orande connector
1 yellow rod
3 green rods
1 blue rod
1 blue 3d connector
1 green connector
Step 18: Build the Back Connector Plate
Picture of Build the Back Connector Plate
The Back Plate
Pieces:
4 Red Rods
9 green rods
3 gray rods
5 White rods
3 Red Connectors
Step 19: Final Attatching
Picture of Final Attatching
Get ready for a !!LOT!!of attaching
Attach he back plate and one the thingies from step 17 (2+3)
attach the back plate and the trigger(4)
Then Attach step 16(5)
Then Fit The two huge chunks together... sorry that part isnt very detailed but it's simple enough when you look at the pictures and the whole pictures.
Then attach the Hinge thingy
And Attach step 12
Step 20: Rubber Bands and Wire
Picture of Rubber Bands and Wire
Now the finishing touches...
Pieces:
16" of wire or string, or less.
1 rubber band
Attach a rubberband to the trigger
Step 21: Optional Display Tripod
Picture of Optional Display Tripod
This is optional. Alas, you can't shoot with it, as it blocks the chain. It works well for display, though.
You have to modify the gun slightly for the stand. It's a matter of about 3 pieces however so you needn't worry
Pieces to change:
1 Yellow 5-slot connector
1 Purple 3d connector
1 blue 3d connector
Pieces:
4 White connectors
5 Red 3-slot connectors
4 gray 2-slot connectors
9 Gray rods
2 Yellow rods
2 silver spacers
2 blue spacers
3 blue rods
1 blue 3d connector
3 green rods
Step 22: Loading and Firing
Picture of Loading and Firing
Loading and firing is simple
Pull, place, and load!
Take off top, put on chain, put on top!
Now push the black arrow up,
And pull the trigger to fire!!
saberwing (author)2010-06-21
how stable are these rounds? i think the rounds look a little volitale
knexsuperbuilderfreak (author)2008-07-06
i bult this but with a 7ft long mag
um... wouldn't that take like... oh, i don't know.. maybe 10,000 PIECES!!!. i mean when i get the huge bin of knex in acouple of days, that only takes me to like 3000 pieces ( yeah, i know, it's a midget knex collection) name one person on this site who has less than 3000 pieces(besides me right now)
I have like... 32000 now...
DJ Radio (author)Darth Trainman2009-11-20
And oodalumps has more than you AND Mepain???? WTF?
im getting 35 lbs(in total)
bighead5454 (author)builder9682009-06-25
i do i only have not even 300 pieces but like 5000 pieces are coming in from ebay so i guess they count
builder968 (author)bighead54542009-06-25
Now I have 6k. :D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D:D
An Villain (author)builder9682009-07-02
why are you sad about that?
Pizzapie500 (author)An Villain2009-09-02
:D is a happy sign
An Villain (author)Pizzapie5002009-09-02
oh, i was reading from right to left.
Pizzapie500 (author)An Villain2009-09-03
LOLz
An Villain (author)Pizzapie5002009-09-04
yeah.
chopstx (author)builder9682009-06-25
-probably me. i have ithink about 20000
imthatguy1125 (author)builder9682009-05-30
me
bounty1012 (author)builder9682009-05-03
propably me
I have no idea how many I have most of them are in my SAW so without those Ive only got about 2000
smilee (author)builder9682009-04-08
i have about 11,000 around there
builder968 (author)builder9682009-01-28
now i have ~6,000 :D
i've got 19000, after lots of eBay, and I'm working on a project that uses a ton of pieces.
Me too, but I also buy from yardsales.
Bartboy (author)Oblivitus2008-10-15
yeah!
grevious (author)builder9682008-10-05
yeah im under 3000 pieces and i need more.
but no job means no money and no money emans no knex =[
plus parents wont give me any -.-
Oblivitus (author)builder9682008-08-03
I think I have around 8 or 9 thousand.
Oblivitus (author)Oblivitus2008-10-04
Now I have around 20 thousand.
Ive got like 3000-4000 Knex peices
i olny have about 1000 at the most!
one word.... EBAY!!!!!!
yea my mom and dad is out of ebay money =)
i like bad grammer<3
zyilo (author)builder9682008-08-22
i have about 5 thousand .. :D
builder968 (author)zyilo2008-08-22
NEED...MORE...KNEX!!!!!!!!!!!!!but school starts in a week...
Soopah Steve (author)builder9682008-08-07
ME!
My mag was like 2 ft XD
DJ Radio (author)2009-09-12
Why did you remove the video?
mettaurlover (author)2009-08-30
as many chain links as you want? that's a bad thing to say around a guy who has aobut eight feet of chain...
bighead5454 (author)2009-06-25
i got around 300 now but i am waiting for 5000 coming in the mail including like 3 or 4 motors
why'd you remove the vid i wanna see it shoot
PineapplebobTheGreat (author)2008-01-24
Trainman,you're cool... (i wish i was cool...)... I bet you are really popular at your school. I'm not really cool, just the guy who makes really funny jokes and makes everyone pee their pants cause they're laughing so hard.
u are cool u made the insane sniper.
Thanks.
your welcome.
Bartboy (author)the dawg2008-10-15
but thats knex cool, not coolcool, none of us are coolcool, we are all nerdswo go on ibles regularily, have no Jobs, and have insane amounts of knex. None of us are knex.
thomaswatton (author)Bartboy2008-11-17
Im not im well popular and bet all of u are aswell ur just puting your self down
Bartboy (author)thomaswatton2008-11-17
Well in my school there are the skaters, the soccer players, the Englishes ( school skippers) and the frenchies( ME)
bounty1012 (author)Bartboy2009-05-12
Skaters and school skippers kinda go together...
oh, and you are not a true knexer, you post nothing, there fore are no a nerd, so none of that applied to you
thomaswatton (author)Bartboy2009-01-02
ye i know i've not posted anything even though i've made my own guns and also i've got about 20+ people into knex guns and ye im in my school soccer team but still craze knex guns
Bartboy (author)thomaswatton2009-01-02
But you are no nerd..... That's the point.
thomaswatton (author)Bartboy2009-01-03
well i still think u guys a pretty cool for ur crations
About This Instructable
10,407views
32favorites
License:
More by Darth Trainman:How to Build PROJECT CHAOSCHAOS, K'nex Ball MachineX985 VIVISECTOR
Add instructable to:
