XBOX 360 Controller USB Hack
Introduction: XBOX 360 Controller USB Hack
I do this hack because my wire was broken and i found no wire on Ebay.
So I solder a USB wire on the controller.
You need:
1 x USB wire
1 x Screwdriver
1 x Soldering iron
1 x Solder
1 x Glue
Step 1: Open the Controller
Open the controller by removing the screws.
Step 2: Desolder the Original Cable
Desolder the original cable.
Step 3: Cut the USB Wire
Cut the USB wire.
Step 4: Make a Hole in the Back Cover
Make a hole in the back cover and stick the USB wire in it.
Then fix it with glue.
Step 5: Solder the USB Wire
Solder the USB wire to the Mainboard.
The pin sequence can you see on the picture or you remember the pin sequence from the original xbox wire.
Step 6: Assemble the Controller
Assemble the controller.
Step 7: Finish!
Now you can test it with a normal USB wire.
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    But you removed the strain relief! Did this turn out to be a durable solution?
    Yes because the wire was broken on that point.
    does this actualy work on the xbox
    ....cuz if it does im gonna do it
    If the xbox have a USB port then Yes
    because i have many usb extension and so the controller have a strong cable that will not break.
    Why'd you use such a small USB cable?
