XBOX 360 Power Supply to 12V Accessory Adapter by Skater_j10
Step 13: Test Fit the Power Connector then Line up and Trace the Switch
Take out your No. 10 Torx screwdriver & screws and test fit your power connector to make sure everything fits right, if not do the appropriate modifications now because it will be much harder to in later steps. After the test fitting is done you can now trace out where you want your power switch to go, please Note that you don't want to interfere with the mounting bracket on the inside so be aware where you are cutting the hole for the switch.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
