Introduction: XBOX Controler Via Usb
It is a xbox controler for the pc for the gamers out there.
Step 1: Be Prepared
Befor you do this you need:
A 2.0 USB port
Solder
Xbox 1 contorler or 360
500mhz computer with 64mb of ram
Xbcd Software
Also If you are using the XBOX 1 controler you need to download XBCD from www.allenthinks.com in the download section.
A 2.0 USB port
Solder
Xbcd Software
Step 2: Download the XBCD Software
If you are Using Xbox 1 controler you need to download the XBCD (custom) from allenthinks.com in the download section.
If and only if you are using the XBOX 360 controler.
Step 3: Wireing It Up
Now you need to splice the adapter THE ADAPTER not the xbox cable. (some problems)
And it is the same wiring diagram as a normal usb cable.
You don't need to worry about the yellow cable just cut it off.
Step 4: Installing
Now its time to install the software FIRST.
This part is alittle rag-tag.(windows on diffrent os"XP,2000,95")
Once you have the software installed plug up the controler and when windows reconizes it chose manual install and then select choose myself(or something like that) and select the controler and it will say that its not digitaly signed but who cares.
Step 5: Checking Your Connections
In order to connections and if you installed it correct open up the XBCD Utility and select gamepad1 (or similar) then open up microsofts game controlers and check.
Then open up your fav game and map the controls.
