3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
XP Security
XP Security
This is a basic way to get into windows XP without a password (normally) incase your sister changes your password etc. It is also a good idea to secure this account in an office, etc.
Also this is not generally a good idea if the PC is not yours. Probably Illegal.
Step 1Start your PC in safe mode
When you turn on your PC tap F8 as it is starting, and before it gets to the XP loading screen it should bring up a list of start options (normal, safe mode, safe mode with networking, last known good configuration etc). Pick Safe mode.
41 comments
1-40 of 41next »
Jan 19, 2012. 9:58 PMINdiSTRUCTable-samoan says:
SWEET - CHEERS BROTHER, so easy yet so effective. I bet this helps a lot of people. Thank you very much for taking the time. Peace brother.
Nov 6, 2008. 7:45 AMthegeeke says:
Did you know that you can get to the old style login without rebooting? (Watch out for the CMOS password when you do that!) To get to the old style login from the standard login: press ctrl-alt-del. You may have to hit it more than once.
Sep 11, 2008. 9:42 PMvrw says:
On XP-Home one can't put a password for admin. Logging in as admin always takes you inside without asking for pwd. ( I was shocked when I came to know) In XP-pro you can put password for admin
May 29, 2008. 5:09 PMkerpaul says:
There's a way to do this for any account (with only the username and an account on the computer / network) search kerpaul.
May 23, 2008. 7:22 AMn4zou says:
Boot the computer with any Linux live-CD, after boot mount the hard drive if your Linux did not do so automatically. Change anything you want in the pass word files. If you want real security load Linux on a USB flash drive and take it with you when you leave the computer. After a few weeks with Linux you can take the Windows hard drive out of the computer because you'll discover how poor an OS it "was" and you never need listen to a hard drive thrashing around like an out of balance washing machine as Windoze scatters data randomly to all parts of the plater.
May 20, 2008. 10:39 AMedgar_brazda says:
You are a pure GENIUS!!!
Nov 21, 2007. 6:06 PMfleetnewsservice says:
"Click it. It will normally enter with no password." Problem with this is that most administrators with some brains will have put a password on that account. My dad did when he found out I was changing settings on our family computer.
Apr 5, 2008. 7:36 AMmilo0is0hot0 says:
well actually i know a teacher who owns a 'school owned laptop' and there was no admin password set by the administrator!
Nov 27, 2007. 12:42 AMx_caliber says:
Your technique is OK! but how to bypass the password if the administrator user already have their password, what i mean here is if someone already put the password before U.
Aug 21, 2007. 5:44 PMvaiden says:
Yep, the way to access safemode is to press F8 just after your pc passes control from the bios to ntldr.exe. This is the end of the POST process also known as power on self test. You can tap it a few times during the beginning of boot and your pc will likely beep at you saying you are too early. Then it will give you a list of boot options. Safemode is a nice one to choose and you can follow stranosters advice, or you could choose to type lusrmgr.cpl at the run prompt. You should not be running XP without an admin pass, because then you are sharing your entire pc over the internet when you are connected. Look at my comments on the other windows password hack instructables for more info.
Jul 13, 2007. 6:06 PMDantex says:
sisters should fall!!!
Aug 4, 2007. 10:55 PMmmzdaniel says:
brothers FTW!
Jul 31, 2007. 4:43 PMcallumadamson says:
thank you very much.. you just saved me loads of work !!!!!!!
Nov 4, 2006. 5:25 PMiceiclepop says:
pshhh illegal shmilegal. Nice instructables oliver, but i already knew about this
Jun 30, 2007. 3:07 AMmyrhymeandreason says:
Doesn't Windows even tell you that you can do that with the Admin account?
Jun 22, 2007. 1:16 PM!Andrew_Modder! says:
(removed by author or community request)
Jun 23, 2007. 11:42 AMclimber_geek says:
Jun 23, 2007. 2:50 PM!Andrew_Modder! says:
..Umm i wasnt the one that screwed up the pc, and the school threw the pc away in the dumpster, cause they had like 10 extra brand new pc's not being used,stowed away in a office-copyroom. Beats me why they didn't call for repair, they were just laisy and threw it away. :-| (if anything i helped recycle.) .sorry if that offended you. somehow¿
May 20, 2007. 2:12 PMacid rain says:
F8 gets me to the menu w/ safe mode on my Fujitsu Lifebook
May 9, 2007. 12:29 AMdasarp says:
Try this instructable on getting Windows Passwords:
http://www.instructables.com/id/SAEPSY3F1B3RBOT/
Mar 26, 2007. 3:34 AMadminsenemy says:
http://www.instructables.com/id/EJOKMPQ2HYEZIXDN23
For local stored data this is better
Mar 18, 2007. 2:35 AMLamaBot says:
Well if I am working at company A at computer B, while the boss is working at computer C and I try the above instructable on computer C without my boss's consent, then yes, it is illegal, by all means. You've got to understand, if you're instructable is not good compared to theirs, they'll put it down. They never compliment the effort you'd made to even make it, a lot of the times. This instructable would be good as a reference, in case of a similar situation ever occurs. Kudos. LamaBot
Nov 8, 2006. 10:30 AMColumbusGEEK says:
Its not illegal by any means. If your work IT department doesnt know how to properly secure the company workstations then poo on them.
Jan 18, 2007. 3:33 PMkutza says:
That is not even close to being a hack... Any office that doesn't have a remote login, should have their IT fired. M'ost don't use local accounts, so this is a moot point in offices.
Jan 14, 2007. 8:03 AMkaputa says:
Thanks it works
Nov 27, 2006. 4:58 PMtAK says:
For anyone who didnt set a Windows Administrator password during the setup, this will work. For everyone else, you will need a Password Reset Disc, they do exist, and they are not at all hard to find, no need to crack anything, it can insert its own password hash. To protect against this? simple... set your HDD as first boot device in the BIOS, if possible, prevent boot from CD/Floppy/USB, and set a BIOS password, if possible (not all bios's support it, set a startup password also (this will be requested after POST but BEFORE windows loads)
Nov 20, 2006. 12:26 PMrevolution says:
i have a program the crax the windows log in password. Its a bootable program that gets the pass within 1-5mins. If you want it, say the magic word.
Nov 17, 2006. 12:45 AMrevolution says:
ah.. nice and easy...
Who doesnt know this =.=
What if the user disabled safe mode ( this is possible for ADVANCED users that know their computers )
Nov 8, 2006. 6:02 AMdomas says:
It was always F8 and it will be. This is the default key on windows (there is nothing in connection with your motherboard).
F8 is for most (windows can be modified etc.) versions:
Windows 95
Windows 98
Windows XP
Except for Windows 3.x while there was no such mode (as I can remember).
Nov 10, 2006. 9:10 PMdev45 says:
in DOS it will give you the option to confirm each line in the autoexe.bat and config.sys
Nov 5, 2006. 4:22 AMtrebuchet03 says:
Mine's f11 ;) or was it f12... I can never remember that one...
Nov 10, 2006. 1:59 PMChairman Wow says:
You don't need to go into safemode to access the Administrator account. If you press ctrl-alt-del at the screen which offers you the choice of which account to log into, you will be given a normal username/password log-in box. Just type in administrator here and click ok.
Nov 5, 2006. 10:01 AMIan01 says:
Doesn't everyone know how to add a password to their account?
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:stranoster
I dunno... I like school unlike a lot of people and love science and mechanics. I remember playing Gizmo's and Gadgets when I was young, and love correcting peoples spelling and grammar on the interne...
more »
