3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Xbox 360 12v fan mod
Step 2Removing the Case
Removing the Case
Picture 1.
First start by removing the faceplate, this is fairly easy, with the xbox on its side, give the base end a firm tug and the faceplate should pop free, don't be scared of pulling to hard, these things are fairly robust.
Picture 2.
Next step is to remove the bottom and top vent covers, to do this use one of the small flat bladed screw drivers, by looking into the holes on the side of the case you should see 3 plastic tabs by pushing against these you can free the vents from the case, there are 3 plastic tabs on each side.
The Top is slightly more tricky. the front tab's are set higher so can't be accessed through the ventilation holes in the side of the case. to unclip these look at picture 3 for guide on how to get to the tabs.
one of the tabs for the top vent is hidden behind one of the rubber feet as shown in picture 4.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:pooley182
