3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Xbox 360 12v fan mod
Step 3Removing the case (continued)
removing the case (continued)
in image one i have circled the 7 clips that hold the back of the case together, these each need to be freed to allow the case to come apart. i will attempt to explain how i do it which i believe to be the easiest way i have discovered.
this is where the two screw drivers come into place.
as you can see in picture 2 if you start at the end of the box with the power connector and push a screw driver into each of these holes, you should hear a distinct clicking noise when the clip is depressed.
once these two clips have come undone use one hand to hold this end of the xbox apart using a small amount of pressure to make a gap between the two halves of the box
now push one of your screwdrivers into the middle of the fan ventialtion section, there are two clips here which come apart with very little force.
now push slightly harder with your hand that is holding the box apart, and proceed to press in the final 5 clips above the video port of the xbox each of these should make a distinct clicking noise as you work your way to the opposite end of the box.
now you have the back spread far enough so that the clips won't go back together turn the box around and unclip the large clips on the front (picture 3).
and remove the base section of the xbox.
Congratulations you have just completed the hardest part of this mod.
now look at picture 4, place your screw driver inbetween the black part and the plastic and pry these apart it should come off with very little effort
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:pooley182
