Step 4Soldering to the Motherboard
Tinning and Soldering
Tinning is the process of applying solder to two separate surfaces, then in one act without applying extra solder bonding those two surfaces. Measure off around 7-8 inches of wire for both the red and black wires going into the inverter. Strip a small amount of sheathing and apply an excessive amount of solder to the end of each wire.
Applying solder to the Xbox 360 pins is a different story, Microsoft uses lead-free industrial solder which melts at a very high temperature. Apply a large amount of solder as best you can to the pins, feel free to hold your soldering iron on each pin for awhile, they can take the heat. Solder the red wire to the number 4 pin (shown in picture as 12v supply) and the black wire to pin 9. Test the physical strength of these connections by pulling on them, if the solder joint is easily broken, hold the soldering iron on longer until that joint is solid.
Testing
Even though the Xbox 360 is disassembled without fans, you can still plug in the cable and turn it on for a few seconds. I'll add in a note of extra caution, players usually get banned from Xbox Live for playing improperly copied games, however booting your system with the power cable not in the DVD drive is cause for suspicion, and could result in a ban. With your wires soldered on, plug the connector into the inverter, the CCFLs into the inverter, and press the power button. When your 360 turns on so should the CCFLs. Be sure not to leave the 360 on for very long without fans running as you can overheat the CPU.
Hot Glue Insulation
As a protective measure, put a blob of hot glue over each soldered point. This will keep the connection from rubbing against the bottom of the steel chassis, and keep the 12v and ground wires from touching.
Re-insert the Motherboard
You can now place the motherboard back into the 360 steel chassis, and align the wires along the back corner of the casing. Make sure the wires emerge from the rear edge of the motherboard (not the side) so that the casing screws are still aligned.
I have purchased these: http://www.ebay.com/itm/PVC-2-x-24cm-Blue-Car-LED-Light-Flexible-strip-12V-/270755022303?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3f0a41c5df#ht_4407wt_1093
and I was wondering, can I solder the strips to different terminals?
e.g Strip 1 goes on (4,9) and strip 2 goes on (5,10).
Oh and I was thinking of running both strips to a master switch, but my searches on Google have been fruitless.
So do you where I could get a master switch which I could wire 2 strips to?
Thank you so much for all your help, and BTW your Instructable on the controller ring of light was excellent for me (I made two nub mistakes, I soldered one LED the wrong way around (Derp), and accidentally ruined a terminal on P3, hence your solder bridge method was well- received) It works great now.
As far as switches, I recommend not using a switch, since the lights will power on or off with your 360 anyways. If you are committed to using a switch, just drive to your local electronics store or Radioshack. They're overpriced, but they have a good selection. You would probably want a small but long cylinder button-switch for compactness sake, maybe just having the button pop out through a side vent-hole near the HDD or something.
I've made a picture for you on how to wire this up if you want a switch. It would work just fine without the button too.
Good luck!
Here is a quick link I found from Xoxide, they tend to be more expensive, and have them for $6 each: http://www.xoxide.com/cocasoackit.html
Enjoy.
I also have a blacklight sitting around. Would it be possible to wire that to some sound reactive microphone?(it's almost funny saying that, since all microphones are sound reactive)
As far as the CCFL tube, yes, you can definitely throw one in there. The only downside, is how to adjust the sensitivity. The best I can think of would be to drill maybe a 1/4" hole through the acrylic tube (unbelievably carefully so you don't crack it. Step up slowly in bit sizes from 1/16 through 1/4 etc), and gripping and turning the knob with tweezers.
It always gladdens me to hear that others are enjoying, learning, and having fun with my instructables. Whenever I make a new invention, I like to make a guide so that others can enjoy it. Thanks for reading them all, hopefully you've gained something, or even shared the creations and your modifications with friends.
You've probably seen my slug cannon instructable, however I need to update it. I've now created a 2 1/2" barrel interchangeable barrel, that can replace the 1". We have been molding ice, plaster, and concrete slugs and using them as ammunition for the barrel. Whatever it hits, it completely obliterates.
The next guide I'll be writing should be a very easy one, a bicycle headlamp using a high-powered LED. There are already a couple of these on instructables, I just think I can write a better one, and this light will be using a 430 lumen LED overvolted to 600 lumens. That's like.... painful bright.
Below is a photo of me holding the slug cannon with its new barrel.
For the most part, when the system is off so are the CCFLs.
I hope this helps.
Now time for me to put this mod back in mine and NOT get RRoD and break the mod in fixing the ring...
As far as RRoD goes, I had it, but I fixed it. My problem was that in the disassemble process, I had knocked one of the heat sinks loose and the xbox would overheat and shut down in a matter of seconds within boot. When I took it apart again to fix the problem, I accidentally broke the thin wire on the CCFL, and thus ruined the whole mod. I will try it again as soon as I get paid.
Can I get a link (preferrably one on instructables) to the X-Clamp fix? I've never heard of it or seen it.
You can purchase every single part at a trip to Lowes for about $12 (including solvents). Make sure whatever washers you get are 1mm, as 1mm off can make a difference between the fix working or not working.
Llamma.org made the first popular and newbie guide for it here: www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
Some users today criticize it as primitive compared to a hybrid fix (more complicated), but I think an X-clamp gets the job done perfectly fine. Also, don't waste any money on heatsinks for the RAM chips, they aren't the issue in the vast majority of cases. Also, never use the penny trick (which does absolutely no benefit of any kind), nor the towel trick (the excess heat damages capacitors and other parts in the box, while it may fix the GPU, within a week.
8 M5 0.80x12mm Hex Bolts
32 5mm wide (or 1/4") Steel Washers 1mm thick
16 1/4" Nylon Washers 1mm thick
Goo-Gone for the majority of thermal grease, it sort of soaks in a bit to break down Microsoft's crappy paste.
Isopropyl Alcohol, for finishing off and polishing the heat sinks and chips.
Paper Towels, and a super-soft cloth for the GPUs (like for eyeglasses or snow goggles).
Thermal Paste, either Arctic Silver 5 (which some people criticize for it's conductivity, it's great though), or a ceramic paste like Arctic Silver CMQ-22G.
This whole process is making sure that 1) The heatsink is applied evenly and with proper pressure to the GPU 2) The overheating process of the GPU will cause the solder underneath to 'sweat' to reconnect cracked wires 3) Make sure that the GPU is completely flat, so thermal expansion and contraction from being turned off and on won't crack any wires with the GPU being slightly flexed like when it is stock.
The overheating process should generally be done for about 45-50 minutes, and a cool-down time of 15 minutes. Leave the box alone while it is cooling off.
If you'd like another 360 project to do on the theme of green, you could always modify your 360 controller LEDs to a brilliant, radioactive green (compared to the stock, dull green), or any other color combination you want @ http://www.instructables.com/id/Xbox-360-Wireless-Controller-Ring-of-Light/
