Step 5Placing CCFLs
Number One
The first CCFL will be located on the right side of the 360 (opposite where the DVD drive sits). Get a sharpie or other marker, and mark on the side of the steel chassis the white ends of the CCFL. Hot glue will go over the white plastic, as the glass tube itself can melt the hot glue and will fall off the case.
Place a large amount of hot glue onto your markings, and place the CCFL down into the blob, then apply glue on top as well, completely surrounding the white end with glue. The Xbox 360 should be on its side while the glue dries, once it is relatively solid you can move on.
Number Two (DVD Drive)
This is the most dangerous part of the install. The CCFL just barely fits in-between the leftmost legs of the DVD Drive, it is possible to crush the tube when reinserting the DVD drive. Seat the drive into the 360 as it would normally sit. From above, hold your CCFL over the gap and mark the ends. View the picture below for a better idea.
Like the first tube, glue the second CCFL to the side of the steel chassis with the DVD drive removed.
For the cold cathodes, you could take the red wire going to the 12v pin, cut it, one end to terminal 1, the other to terminal two.
With three connections, you can make it that both directions on the switch do something. This matters more for monitoring, so the third would be connected and say, "heya, the switch is disconnected/on", so don't worry about it.
Enjoy!
But it's finally done and here's some photos.
The picture is a geisha and was reverse-engraved on the plexi. The window was laser cut and i broke 2 cathodes..... >.
I have a dremel, but something about laser cutters...
