Step 4Removing Existing LEDs
Floating
Microsoft used a small amount of solder to connect the LEDs to the wireless board. In order for us to remove the LEDs, we must add extra solder to each of the three LED terminals. Simply touch your soldering iron to each terminal and add your soldering coil to bathe the terminals in solder.
Tapping the Terminals
Once the LEDs have been floated, you must have all three terminals molten at the same time, after which the LED should just float off of the board. Tap the soldering iron back and forth between the three terminals, and the LED should be pushed off the board without requiring any extra effort from you. If you push with too much horizontal force on the LED instead of letting the LED fall off on its own, the LED can tear off its solder terminals from the wireless board, making it extremely difficult to make that LED location functional again.
Cleanup with the Soldering Braid
After you have removed the preexisting Microsoft two-color LED, remove the solder present on the three terminals. Take your soldering braid and rest it on top of the terminals. Push your soldering iron downward towards the wireless board and the solder will absorb into the braid. You should end up with three relatively clean and flat terminals.
Add Comment
