Step 5Attaching SMD 0603 LED
Tin the Iron
Since you only have two hands, it would be hard to use a soldering iron, solder, and tweezers at the same time. So first we will tin the soldering iron. Apply a decent amount of solder to the iron, enough so that if you touch the iron to the LED itself (no external solder added) solder would stick to the LED.
Grabbing the LED
Use your tweezers to flip your SMD around until you have the negative side pointing in the proper direction. You will then flip it on its side, grab it with your tweezers (you should be pinching the top and bottom parts respective to the LED) and place it over your wireless board.
Soldering the Terminal
While holding the LED sideways over its terminal points, (The direction marker pointing to the green negative terminal), touch your tinned soldering iron to the LED and terminal on the wireless board, and it should hold in place. Now solder the positive end of the LED to the other terminal. Make sure there are no short-circuits where solder has connected multiple terminals together.
Add Comment
