3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Xbox 360 Ring of Light LEDs
Step 6Test and Repeat
Test and Repeat
  • last photo ←
After you have soldered in your LED, plug the wireless board back into the Xbox 360 to test if the light works. You must have the video cable plugged into your Xbox 360 in order to get the four player LEDs to light up (Otherwise it is only showing the red/error LEDs that the video cable is not plugged in, which would not be lit for us).
If it worked, excellent, you may continue on to doing the other four. If not, make sure that solder is not connecting any terminals together (such as green negative to red negative). Also make sure that your orientation is correct, and the positive is in fact connected to the positive terminal.
Repeat this process for all the LEDs, and you should have a brand new ring of light. Put the Xbox 360 back together and enjoy!
16 comments
Aug 12, 2011. 5:59 PMstephin99 says:
wow did this and when i was testing out did   /    in white and when tested
the other      \    are the original leds but they were red coool???!?!?!?!?!?!
it works and all but makes me wonder what made it do that........
Dec 17, 2009. 4:36 PMwil0016 says:
hay im doing this today and was wondering does it matter what the mcd is in the LED cause if i use a 600mcd red LED insted of the 500 mcd in your decription does it matter or its just gonna be brighter????
thanks mate
Dec 10, 2009. 9:46 AMStanvdmeer says:
If you still find it hard to see where you have to solder exactly (, like i did), this tutorial may help you! www.mmmonkey.co.uk/console/other/360-rol.htm I find it a little clearer than this one, because the tut from mmmonkey is better to understand if you don't know where to solder, what the positive and negatives are, etc.
But still a great tutorial dude!
Dec 11, 2009. 10:53 AMStanvdmeer says:
I think it is just a good replenishment to your tut, because the guy also explaines about the red ERROR LEDs 'n stuff. I don't say it's better than yours, but I found a combination of yours and that one clearer.
Jun 25, 2009. 10:23 PMstikman says:
With the original LED's removed and no LED installed for an error light, how would you know which error has occured without knowing how many lights are flashing?
Apr 28, 2009. 9:51 PMtj the gnome says:
and then you run it on carpet... CHERISH THOSE THINGS!!
Jun 1, 2009. 9:43 AMtj the gnome says:
ohh well that's good. i was gonna say, anyone who has the electronic prowess to do this should know why NOT to run an xbox on carpet.
May 26, 2009. 3:05 AMNissanine says:
i has a question, do u hav to remove the whole casing of the exbox or just the facyplate?
Nov 23, 2008. 7:54 AMjam3s08 says:
Hey Great Guide. I was just wanderin though do u do it the same way for the controller if so wat size/volt are the LEDs cuz i dont wanna try it on my xbox yet. Thanx. Just send a comment or even better send an email 2 jameshenry101@hotmail.co.uk. thanx
Nov 17, 2008. 7:34 AMOrion370 says:
My God Man... That is awesome. I think once my warranty runs out Im gonna do this. Id rather let M$ Pay for my repairs while I can :D
Nov 17, 2008. 5:16 PMOrion370 says:
How did you go about putting the cold cathodes into your xbox? Those look pretty sweet also. Is there a website that would show or is there another instructable? Worst comes to worst, I just put some LEDs in there I suppose. Great Job though. Def keep up the good work, and my warranty runs out soon enough. July 09. I think Im gonna try on a dead xbox's wireless board first.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
161
Author:QuackMasterDan
I have a passion for tweaking things. Whether it be modding video game consoles, creating custom laser displays, or any creations with lights I love solving problems through unorthodox means. I like ...
more »
