Xbox 360 Wireless + Arduino
Introduction: Xbox 360 Wireless + Arduino
Purpose :
Quick setup to get your robotic projects
wirelessly controlled with an Xbox 360 Controller
*Update ( 11 / 24 / 2015) :
If using the pc and having trouble ( especially with adapter not being recognized or having a green solid light) try the following:
Author :
Sergei Dines
Writer - Inventor - Philosopher
MECH Database :
Includes : Servo CAD Files, Arduino Codes, Robot Project Ideas , and whatever you'd like to add
Step 1: PARTS
  • Xbox 360 Controller : Here
Note : has to be Microsoft - Do not cut corners else I cannot promise it will work with other controllers / receivers
  • Xbox 360 PC Adapter : Here : Also , THIS ONE is confirmed :
  • Arduino Uno : Here Should Come with PC Cable
  • Usb Host Shield : Here
Total : About $98
But : Once you purchase this setup, you can control servos, motors, and any robotic project wirelessly
Step 2: WIRING : Connections
  1. Connect USB Host Shield to Arduino Uno
  2. Connect Xbox 360 Wireless Reciever to USB Host Shield
  3. Plug Arduino UNO Into PC
Step 3: COMPUTER : Software + Libraries
  1. Download Arduino IDE : Here
  2. Download USB Host Shield Library : Here : Scroll Down a little and Click " Download Zip" Right- Hand - Side
  3. Import Library by following the steps on Arduino Website : Here
  4. Close out Arduino IDE and Open it Again
Or Follow These Steps to Import the Library :
  • Open Arduino IDE
  • Sketch --> Include Library --> Add .zip Library ...
  • Add Zip File from Step 2 Above
Step 4: Confirmation
To Confirm :
  1. Open Arduino IDE
  2. Go to File [ Upper Left Hand Corner ]
  3. Examples
  4. Scroll Down to : " USB_Host_Shield_2.0-master" Or whatever you called the .zip library
  5. Hover Over " USB_Host..."
  6. Select Xbox --- >XboxRECV
  7. Upload Sketch to Arduino
  8. Open Serial Monitor [ Upper Right Hand Corner of Arduino IDE ]
  9. Should see the name of the button stressed followed by a number
Arduino Interface image from :
Step 5: CODE : Controlling Robotic Arms & Rovers & Stuff
  • OR Below -- > servo_xbox360_simple = my own code ( very simple and easy to follow )
  • Any questions / contracted work email :
See Codes Belowfor older version of code and another to control motors with speed control
See :
  • -For Controlling a robotic arm with the Xbox 360 controller [ 6 Servo control CODE INCLUDED ]
Note * Motor Control Sketch May Need Editing + Confirmation but should work
Step 6: Conclusion
I'd like to thank Barrett Anderies for helping me with this setup
He has a similar setup, but with a PS3 Controller : see Here
Step 7: Troubleshooting
  • Receiver Light Not On When Plugged Into USB Port ----- > Switch USB Port
  • USB Host Shield Library Not Recognized / named correctly ---- > Get rid of periods, special characters, spaces, or numbers - don't start name with number.
  • Weird characters are showing up in the serial monitor --- > Match " Baud rate" within code with serial monitor baud rate
  • Weird characters are still showing --- > Make Sure XboxRECV Selected [ as mentioned in comments by CarsonH2 ]
  • Sync or Avrdude error --- > Select Correct Board [ Arduino Uno] , Port, and Programmer [ ArduinoISP ]
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    Hi, I don't know if this problem has been resolved yet, but my receiver will not show a solid green light when connected to the USB host, but it does when connected to the computer. I can press the sync button on the receiver and then the light will blink for a little bit, but then it will turn off. I do not know if this is a hardware, software, or battery power issue. Please let me know if anybody has resolved this issue. (And yes, I tried changing the USB port and it did not work). I'm using Arduino uno.
    my receiver won't show a solid green light when I connect it to the usb host shield and the Microsoft help page is no longer availiable. What can I do? I'm using the SainSmart USB Host-Shield with an Elegoo UNO R3 and the original Microsoft Reveiver.
    I'm Having the same problem. Using SainSmart USB Host-Shield, arduino uno, xbox wireless adapter for windows, and xbox one controller. I have tried connecting to pc, the dc jack, and the Vin pin but I cannot get the adapter to power up on the shield. The adapter works fine when connected to the pc and syncs with the controller easily, so no problem with the adapter. Any suggestions??
    I'm using the ATmega 2560.
    so far, I've got the controller to communicate with it.
    now all I need to do is have it control a few DC motors, though the code isn't working right and I can't find anything on how to wire DC motors up to the arduino(fairly new to this) any help would be most appreciated
    to hook up some DC motors you will need to buy a DC motor Board. You can get one for a 2WD or 4WD car. Also you should get an extra battery pack so that there is extra power for the motors.
    What code did you use to connect/communicate the Xbox controller with the USB dongle?
    1 - If you haven't already, I'd suggest getting the arduino with those chips ,not just smd stand alone
    2 - email me at and I can help with the motors
    Would i be able to use stepper motors instead?
    @Sergei Dines I just want to know one thing is the Left and Right Trigger buttons i.e. LT and RT on the XBOX ONE or the XBOX 360 Controllers Analogous(0-255) or they just digital switches(0-1) because I love these controllers and I want one of these to fly my quadcopter and since the analog sticks both are center spring stick. I cannot use either of them for Throttle for my quad copter so I thought if the triggers were analogous I might be able to use the triggers for throttle.
    I haven't gotten the Xbox One controller to work with this library, but I've used the 360. The triggers (LT/RT) are analog, 0-255. Of course, these have springs as well. But the bumpers (LB/RB) are digital.
