3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Xbox 360 Wireless Controller Ring of Light
Customize the four player indicators on your Xbox 360 wireless controller by removing the stock LEDs and replacing them with any color of your choosing. I've received a lot of requests for this guide, which will show how to dismantle and upgrade an official Microsoft controller.
***Disclaimer: I am not liable for any damage that may be caused to your property or self from following the instructions in this tutorial. Soldering irons can be very hot and cause burns, as well as possibly break your Xbox 360 controller. Opening your controller's shell will void its warranty. If you are unfamiliar with soldering I suggest you acquire some practice on blank boards before attempting this mod, as the LEDs are quite small. ***
Step 1Supplies
The parts list for this project is small and fairly cheap.
Soldering Iron: Your generic 10-15 Watt Radioshack soldering iron, available for about $15. Though not necessary, for small projects like this I take a metal file and sharpen my soldering iron to a fine point. It will make the install much easier.
Silver Rosin Solder: Also available at Radioshack, silver solder more evenly distributes heat, and rosin creates a clean bond between two metals. Around $3.
Copper Desoldering Braid: This thin wire braid will absorb solder when placed inbetween the soldering iron and a terminal that needs to be cleaned. Necessary to create a flat base for the LED to sit on, makes the install much easier and can fix mistakes. $3.
Xbox 360 Wireless/Wired Controller: Microsoft controllers are available at any store that sells video game equipment. Retails for $50.
SMD 0603 LEDs: You can select whatever colors you wish for this mod, this instructable uses four blue 0603s. I would encourage you to purchase the brightest mcd rating you can find, the difference between a dim (120mcd) and a bright (400mcd) 0603 is around 10 cents per LED and worth the extra cost. Though you will only need four for this mod, purchase 8-10, these lights are so small you are going to lose some no matter how careful you are. Here are my recommendations from unique-leds.com
Red 500mcd, $0.33/LED (800mcd are available on eBay).
Yellow/Amber 130mcd, $0.22/LED (350mcd are available on eBay)
Blue 380mcd, $0.34/LED (800mcd are available on eBay).
Green 200mcd, $0.39/LED (1000mcd are available on eBay).
White 800mcd, $0.38/LED (2500mcd are available on eBay).
My favorite eBay sellers for LEDs are HKJE LED Lamp Center and Light of Victory Hi-Tech LED Store.
Security Torx T8H: Xbox 360 controllers have security screws, meaning there is a pin sticking out of the center of the screw that prevents a normal T8 Torx from fitting in. If you are cheap or don't want to wait, get an awl or a very small flathead screwdriver, and crack off the pin with a good whack from a hammer, letting you then use a normal Torx driver. I suggest purchasing your T8H screwdriver from Llamma.org. High Quality $7.99 and Low Quality $2.48
Tweezers: Absolutely necessary to hold the very small SMD 0603s. Try to purchase tweezers with the flattest edge you can find, round endings will cause the LED to shoot outward when you tighten around it. Around $3-5 at any local store like Walgreens.
110 comments
1-40 of 110next »
Apr 5, 2012. 8:44 AMDIY_Enthusiast says:
I finished my controller and it works great with regular batteries and while plugged in, but the lights don't work at all with my play and charge battery pack or with rechargeable batteries. I think it is due to the lower voltage put out by them. Is there any way to fix this? Thanks in advance!!
Mar 31, 2012. 8:50 PMstang0522 says:
i did this to one of my controllers and swapped the green leds for red and couldnt bet happpier with the result. and this is where my question comes it.... i tried putting blue ones in a different controller and when i was done it lit up but was extremely dim. so i took it apart and checked the solder points and they were all ok. so i put the battery pack in and turn it on while it was apart and they were still very dim but as soon as i touched the soldering iron to them they got very bright? do you know why that is? are they defective LEDs or what?
Mar 31, 2012. 10:27 PMstang0522 says:
See that would make sense because I was trying to do it on a newer controller, but then switch to and tries changing them on an older one and had the same problem, it doesn't matter what color I try they air dimmer than they should be. The only color that lights up correctly is red. Could it possibly be just bad LEDs?
Oct 18, 2011. 10:02 AMTaranis says:
I have a small question for you QMD.
"Is it absolutely necessary to remove the rumble motors, or is it simply to make the mod process easier?"
BTW Portal case looks amazing.
Oct 19, 2011. 2:12 AMTaranis says:
Ah, my apologies.
You, rather kindly, have slightly overestimated how experienced I am in this field of modding.
I am incredibly new to this, and all I wanted to know was that if it was possible to reattach the rumble motors after you removed them during the process of changing the ring of light leds.
However thank you so much for your rapid reply, and for your links and preferences with regard to LED sellers, esp Hi-Tech LED Store.
Unfortunately uniqueLEDS' shipping cost was slightly too much, so I settled for these, BTW I live in the UK.
http://www.ebay.co.uk:80/itm/ws/eBayISAPI.dll?ViewItem&item=350361893227&ssPageName=ADME:L:OC:GB:1123
Oct 14, 2011. 3:19 PMCharlie2652 says:
Do you know if after modding your led lights if the rapid fire mod (when soldering one end to the player 1 led) would still work?
Oct 17, 2011. 9:06 AMCharlie2652 says:
Yes I'm using the P1 light so when I press the momentary button on the back (that I installed) the frequency of P1 send signals to the trigger making it shoot really fast. See this instructable for what I followed. I believe it should work but I wanted to consult first. Thanks for you help.
http://www.instructables.com/id/Done/
Apr 16, 2011. 5:27 AMRoddyTheGreat says:
heres mine :D i drilled out the buttons and put LEDs into them and powered them using the main power feed on the back of the board :¬D
Oct 8, 2011. 2:49 AMjtc0520 says:
Is there anyway you can go in to any detail on how you did this? I would live to be able to incorporate this in one of my controllers or all 8 =D thanks in advance for your help.
Oct 8, 2011. 6:32 AMRoddyTheGreat says:
http://www.instructables.com/id/Light-up-a-Xbox-Controller-with-LEDs/
This is pretty much how I did it, my LEDs were slightly bigger though so i had to drill out the button more. :D good luck with your modding
May 2, 2011. 12:37 AMjbell1 says:
oh wow nice portal case!! <3
Apr 14, 2011. 3:44 AMRoddyTheGreat says:
How bright (in MCD) are the standard Xbox leds? and what would an 80mcd, or 150mcd blue smd led look like?
Mar 3, 2011. 5:57 PMMunchys says:
Odd i modded one of my controllers with a blue led off this instructable but like in the pic my p2 and p4 leds are brighter than the others
Jan 28, 2011. 2:55 AMjonomon2002 says:
just ordered a soldering iron and some ultra bright blue 0603 SMD LEDs so ill be laying off the coffee for a while so my hands are steady when i have a go at this thanks for the informative instructable
Oct 13, 2010. 2:08 AMCJSinc95 says:
this would be great for me to do as ive done all this sort of stuff before even though im only 15 unfortunatelly i live in australia any suggestions where i could get all this over here?
Jan 14, 2011. 3:09 PMcamferret says:
I'm Sorry to ask but would these ones be correct?
Thanks
http://cgi.ebay.com/50p-SMD-SMT-0603-Bright-RED-LED-Lamp-Light-550mcd-/370390422487?pt=LH_DefaultDomain_0&hash=item563cfd53d7#ht_3820wt_905
Jan 15, 2011. 2:44 AMcamferret says:
Thank you so much
Oct 14, 2010. 12:56 AMCJSinc95 says:
thankyou SO much i had a look at the seller and managed to get everything i wanted to hardmod my 360 elite 360 slim and my controllers with some custon light colours and cold cathode tues inside the xboxes.
Now just to wait until the prcel gets through though knowing my local post office from past parcels they will give me a 3rd conformation letter the first time they 'TRY' and deliver it and ill have to go pick it up before they throw it >:(
Oct 14, 2010. 6:58 PMCJSinc95 says:
do you know of any actual stores i could buy them from because im easily able to ge to the local shopping centres and the city
Dec 21, 2010. 3:19 PMdumdog927 says:
thank you it was a quick fun project!
Aug 30, 2010. 7:40 PMch0wderdood says:
epic portal xbox 360 case :) !!!!!!!!!!!!!
May 21, 2010. 9:01 PMduct tape says:
Could you explain a little more on how to fix a controller with one of the led contacts removed? It always happens to my P4 LED's while installing a new one. All of the others are fine.
May 21, 2010. 10:08 PMduct tape says:
is there any special way to tell what trace it is or just follow the lines?
btw., i read the other comment a few minutes after i posted. It would be helpfull if you could post a pic of a fixed one
May 22, 2010. 8:50 AMduct tape says:
Thanks man.
May 7, 2010. 8:04 PMbradleypatten says:
would these leds be ok jaycar.com.au/productView.asp
1-40 of 110next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
161
Author:QuackMasterDan
I have a passion for tweaking things. Whether it be modding video game consoles, creating custom laser displays, or any creations with lights I love solving problems through unorthodox means. I like ...
more »
