Xbox One Controller - Thumbstick Fix Without Replacing the Module
310,365
31
36
Posted
Introduction: Xbox One Controller - Thumbstick Fix Without Replacing the Module
Here I show you, how to fix a broken Xbox One controller stick module, without replacing the module.
Hope you understand everything, because my english isn´t very, well.
After my third controller broke down and I was really sick of
send every month a controller to Microsoft, I dissassembled my controller and tried to figured out what happend always to my left stick, because the problem was always the same.
I don´t know how durable this fix will be, because I could only test it about two weeks, yet. But until now it seems to be good and maybe I will try this on my next new controller, I think it avoid them for breaking, too.
What kind of problems fix this tutorial!?
Use this fix when your thumbstick, makes noises while moving/pressing down and isn´t stable
You will need:
- Torx screwdriver T8H + T6, or you can try it with a slot screwdriver
-Soldering Iron
-glue, I used superglue, but better is epoxy, thanks to the user msav, who can confirm that this makes the controller very durable
Step 1: Dissassemble the Controller
Start with dissassemble, the controller case.
Then desolder the wires from the rumble motors ( red and black wires), and from the rumble
motors in the triggers ( grey and black wires ). After that screw off the two screws shown in the 2nd picture, then you can remove the board carefully.
Step 2: Look Up the Broken Thumbstick
If you removed the board, look up your broken thumbstick. There must be a grey piece of plastic at one side of the stick module. It is on the left side of the module, if you look on the board from above, like shown in the first picture.
Step 3: Fix the Stick Module
When you locate that grey plastic piece, move the thumbstick a bit around and look if the grey plastic moves. When it moves or there is space between the grey plastic and the metal square, it must be fixed. I used superglue to fix it. You must put it in the space between the grey plastic and the metal, but be very carefully, if you use too much glue, it could be damage the button under the grey plastic, which is the button when you press the thumbstick down.
After that you can assemble the controller.
Step 4: Notes
*In stock the grey plastic is only clipped, but the clips are too small and the material too weak
*If there is no grey plastic piece, where it should be, look in the case of the controller, maybe it jumped off (This was the case in one controller from me)
*If the grey plastic is like it should and dont move, then you have got another problem with the controller
*If the button for pressing the thumbstick down, dont work after doing the fix, maybe you used too much glue and the button is sticked
Ok, hope it helps some people and hope that microsoft will edit the Xbox One Controller soon, I really like the controller but with this problems its really sick.
Good Luck and be carefull with the glue
    • Space Challenge
      Space Challenge
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    36 Comments
    An additional little tip: if the thumbstick "broken" off, superglue works great. But even better: there is a small hole that is the same "gauge" as a large paperclip that runs through the stick.. You can cut a piece to fit (about 3/8"), superglue each end as you insert it into the stick/broken part. That way it is a little more reinforced.
    I just used this exact fix with one change, I happened to have some stainless steel wire of the same size. very strong repair and I also chose to insert a piece into the unbroken sticks shaft. preventive measure and one I reccomend to anyone willing to open an undamaged controller. I will be doing it to all my current and future controllers.
    What size wire? Where can I find that wire? Can you post pictures of your work, epoxy sounds great but glue only... never works for me. I hope you see this and can reply! Thanks in advance!
    Anyone know if the new S controller still has these grey clips?
    Yes they do. I bought one on black friday, 2 weeks in left stick broke, returned it got new one not even 48hrs into the replacement the left stick broke again. opened it up outta curiosity and sure enough I noticed that this clip was broke and causing it to pop/grind. I wish id have seen this post a year a go because this is spot on to whats been happening to all my controller (elite, Halo version, S) its fckn bs that MS is doing this to its consumers.
    I ended up investing in a Cronusmax Plus. Unfortunately about the same cost as a controller. It allows you to use most controllers with the xbox one (and other consoles). So I'm now using a crossover 360 controller (with the wireless receiver).
    However, the XB1 needs to first authenticate an XB1 controller before plugging in the 360 controller after each power cycle. Supposedly you can use a USB hub to negate having to do this each time the console powers off/on. Unfortunately (through the hub) I've not been able to get it to auto-authenticate after a restart.
    Also most headsets cannot be used through controller; only a select few. Although there is a two controller method as a workaround.
    m not sure if this is the correct place to post or not ,sorry in advance if it is not,
    My ten year old son has put the batteries in the wrong way round and mow the controller refuses to run on battery power it doesnt recognise the batteries at all is there a reset or fuse that can be replaced,it still works via usb so i believe its F.U.B.A.R ed any advice would be greatly appreciated,Thnaks in advance,Andy T
    im not sure if this is the correct
    Try this fix, it worked for me and was easier.
    https://youtu.be/moEjjFJIZzo
    My left thumbstick moves forward but doesn't "stick" in that position (yet). If I pull back on it, it stops for a few seconds but that is really annoying if you need to stand still while you make a shot. I don't play Madden or that kind of game, so I guess mine has lasted longer. I bought it right after Xbox One came out and it just started failing. You're right about the new Xbox One controllers being cr4p compared to the 360 or even the Original Xbox controllers. They even make creaky noises if you squeeze them. I'd go back to my 360 controllers in a New York minute if I could. Anyway, thanks for the info GregorJ1.
    Thanks for the info.
    Do you know what that part actually does? Mine seems to work just fine without it!
    I'll be fixing it with epoxy anyway, just in case.
