Here is how I added an extension to a bicycle so I could haul boxes of vegetables from a farmer's market. The Xtends unit uses a discarded bicycle frame and some electrical tubing. My cost was under $20 but the Xtends unit could be built for free if you have a good recycle pile.
The Xtends unit can be removed to return the bicycle to its normal configuration.
The Xtends unit involves welding. For a similar conversion that does not require welding see: http://www.instructables.com/id/Homemade-Sport-Utility-Bike-SUB/. Step 9 has some suggestions on how to make the Xtends unit without welding.
NOTE: I have added Step 11 to show you a way to make the Xtends unit that is simpler and stronger. Please check it out.
This project assumes you have some experience disassembling and reassembling bike parts. See this Instructable (http://www.instructables.com/id/How-to-Build-Up-a-Bike/) to get some idea how this works if you are not already familiar with it.
This project involves welding EMT conduit. Please see my Instructable for suggestions on ways to do this with a minimum of risk: http://www.instructables.com/id/Welding-EMT-Conduit/
Remove these ads by
Signing UpStep 1Select A Bicycle
I pulled this frame from my scrap pile after it had been stripped of handlebar, brakes, chain, front fork, etc. It looks weird because I just put parts back on it that I had lying around. It does support the idea that you can use whatever bike you have as a starting point.
I will call this the "main bike" from now on.
Might be fine if you do a very small amount in a well-ventilated area, just wanted to point it out. I wish they sold non-zinc coated steel conduit, because that stuff is a) cheap, and b) would be great for projects like this.
http://www.instructables.com/id/Bicycle-cargo-trailer--200-lb-capacity%2c-%2430-for-pa/step11/Safety-considerations/
I prepare the area of conduit where the weld will be. I vaporizing the galvanized coating with a MAPP torch (done outside!). Then I use a flap-pad abrasive wheel to polish the welding area on the tubing.
I do my welding outside my basement door with a 20" fan positioned so there is a constant flow of air away from my work area. Even when I am using old bike frame tubing I work outside and make sure the fan carries the fumes (eg. paint fumes) away from me.
Thank you for the warning message. Welders come with DVDs these days and there are good safety tips shown there. Be extra careful of any fumes!
Good advice. Thanks!
I think my photos make the pedals look closer to the ground than they really are. I have to tip the extended bike to 40-45 degrees before the pedal hits. That is a lot more tip than I would care to do riding, especially loaded.
The main reason for that angle-matching stuff in step 3 is to get the chainstays of the Xtend unit to line up with the chainstays of the main bike. You can see this in the first photo in the intro. The chainstays are parallel with the ground and so the pedal height of the extended bike should be the same as it was before the extension was added. (I think.)
You could raise the pedals by adding some blocks between the Xtends unit clamp and the seatstays of the main bike. The angle that the Xtends unit makes with the main frame is easy to adjust.
The veggie boxes I want to haul are about 12" X 12" X 16" and weigh up to 40# each. If I build side platforms down around the level of the axle I could get wo on each side and one or two over the wheel. (I hope that big a load won't happen very often.)
BTW the step-through frame choice was pure chance but it definitely makes it easier to get on and off the bike when it is loaded.
i keep racking my brain trying to figure out ways to make a long bike without a lot of precision cuts and welding (which i can't do). this design is pretty basic. very clever, bikeframe!
and you like the way it rides? does it feel heavy or shaky?
The main bike weighed about 35# and the Xtends unit adds another 12#. The bike without a load is steady and solid. I have not ridden it yet with anywhere near the 200# load I am shooting for. I will strap on some cement blocks and let you know how it goes.
One suggestion I have had is to put a smaller load platform on each side and lower down. A lower center of gravity would probably give a steadier ride. The load carrier can be configured many differnt ways.
smart of you to choose a step-through frame for the main bike. good thinking all the way round.
