3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
YACS (Yet Another Charging Station)
A charging station for your gadgets.
Supplies:
Rubber grommets
A box
Tools:
Drill and bits
Step 1Find a box.
Find a box.
Any old box should do. I picked this one up at the thrift store for a buck. I think it was a silverware box. The main thing I wanted to show here is the grommets I Found at the hardware store. The project itself doesn't differ much from the others on here, but the grommets were a nice touch to finish it off and help hold the cords with their "gripiness".
36 comments
Apr 2, 2008. 1:05 PMsamanthadarko says:
This is Exactly what I have been waiting to see. You rock! how ever I never did consider the heat factor. how would a PC fan work in that situation?
Feb 26, 2009. 3:43 PMsanty22 says:
a normal sized one should do, i dont know if it shold be sucking or making air enter...
Jun 27, 2009. 8:09 PMxd12c says:
One on each side creating airflow should work very well. Would there be any way to add a button to turn the power strip off, thus allowing you to leave the station plugged in without it drawing power?
Jun 28, 2009. 6:23 PMxd12c says:
I was thinking more along the lines of 2 mechanical switches. 1 for the power off & 1 to push the power button to on. If I think of anything I'll pass it along :)
Jun 28, 2009. 6:27 PMxd12c says:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106104
PCI slot fan which would fit very well into your box. Add a "vent" on the other side or back & you should be good if you can figure out how to power it.
Dec 8, 2008. 6:55 AMgoogbar says:
Yours look the best around. I'd go with the guys, add a heatsink + fan. Giving a 3.
Mar 10, 2008. 8:38 AMxrobevansx says:
I added a USB hub to my charging station so the devices that can hook to my PC (virtually anything I charge: phones, pdas, cameras, etc) have a convenient place to link up to the PC!
Mar 31, 2008. 6:26 AMxrobevansx says:
please edit your instructable if you do!
Mar 23, 2008. 12:40 AMstevo1994 says:
Hey I have the same exact phone as you! Wow, what a coincidence!
Mar 19, 2008. 9:10 PMajmontag says:
a spade bit doesn't ever need a pilot hole... just saying is all.
Mar 20, 2008. 9:56 PMajmontag says:
aye, captian! way to keep your head in the came, i see that you also noted that it was a thin material, chipping way easier, another option would be to use a forstner bit, but they may be pricey and... not around while you have your mind set on the project...
Mar 19, 2008. 5:21 AMthematrix says:
Great idea, I would be concerned it might be fire hazard having all those cords wound up and concealed in a box, may be a PC fan mounted in the side might be the go.
Mar 19, 2008. 11:19 PMMr. Rig It says:
This is the nicest looking one yet. Good job and you get a + from me.
Mar 17, 2008. 10:19 PMSDx says:
if you had time....aside from installing switched, i'd also carve out shallow grooves in the size of the device...
Mar 15, 2008. 9:16 PM1up says:
Very nice, that looks good! One thing I would do: add some rubber on the top so your gadgets don't slide around.
Mar 10, 2008. 12:30 PM!Andrew_Modder! says:
nice. just one mod i would persionally make, is to put power switches on each individual charge hole.
Mar 11, 2008. 7:11 PMcarrierpilot1357 says:
i see a comment from you on 90% of the instructables i look at!
Mar 12, 2008. 2:00 PM!Andrew_Modder! says:
ya, i like giving feed back. ..why do you say?
Mar 15, 2008. 7:42 PMcarrierpilot1357 says:
im just saying its cool that someone looks at so many instructables.
Mar 16, 2008. 12:46 PM!Andrew_Modder! says:
lol ok, i thought you were like saying its bad cause theres been a few people that get pissed off at me for commenting a lot of instructables (...oddly enof, lol i dont get it). and ya :-) i try to comment and feedback what i can on new ones
Mar 15, 2008. 7:47 PMcarrierpilot1357 says:
i was using the camera. nice!
Mar 11, 2008. 4:03 PMGorillazMiko says:
Awesome! Very nicely done. I'm eating Starbursts right now, and for some reason, I want to try out this Instructable. Great job. +1 rating.
By the way, is that a Zen?
Mar 11, 2008. 10:45 PMRage says:
i have a zen!!!! its the 4 gig one. but im getting sd cards for it cause its full. how bigs yours?
Mar 11, 2008. 5:44 AMgmjhowe says:
if u wernt too precious about your desk, i would build this into the top! would be great, just 6 gromits poking out the back.
Mar 10, 2008. 4:35 PMLinuxH4x0r says:
Cool! Much nicer than the other ones I have seen. Nice Zen!
Mar 10, 2008. 8:27 AMPKM says:
I'd be tempted to put clipped zip ties around the end of the cables to stop them slipping back inside the box (if the friction of the rubber isn't enough), but otherwise it's a neat take on a useful project.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:tyep
