Introduction: YATC5 - Temperature Controller Assembly Instructions
Picture of YATC5 - Temperature Controller Assembly Instructions
The YATC5 is designed to make the fermentation of foods as easy as possible. Version 5 has many unique features. It is available for sale in kit or assembled form.
  • Waterproof - 3' long temperature probe
  • Datalogging - drop in bluetooth module or TTL serial
  • 100% Open Hardware
  • Digital Display
  • Celsius or Fahrenheit configuration
  • Memory - save settings through blackouts
  • Wide Temperature Range ( -67F to 257F) ( -55C to 125C )
Step 1: Blank PCB (top Side)
Picture of Blank PCB (top Side)
Step 2: Blank PCB (backside)
Picture of Blank PCB (backside)
Step 3: Place and Solder 28-pin IC Socket (U1)
Picture of Place and Solder 28-pin IC Socket (U1)
Note:There is a dimple on this device. It should be oriented to the right side of the circuit board.
Step 4: Place and Solder Slide Switches (S1, S2)
Picture of Place and Solder Slide Switches (S1, S2)
(S1) - Fahrenheit vs Celsius
(S2) - cool vs heat
Step 5: Place and Solder (R1, R2, R3)
Picture of Place and Solder (R1, R2, R3)
300 ohm resistors [orange, black, brown, gold]
Step 6: Place and Solder a (R1)
Picture of Place and Solder a (R1)
1k ohm resistor [brown/black/red/gold]
Step 7: Place and Solder Diode (D2)
Picture of  Place and Solder Diode (D2)
Note:The black line must be on the right side of the circuit board.
Step 8: Place and Solder the 16-pin 595 Mux Expander Chip
Picture of Place and Solder the 16-pin 595 Mux Expander Chip
Note:There is a dimple on both devices that needs to be oriented on the right side of the circuit board.
Step 9: Place and Solder Decoupling Capactiors (C1, C2)
Picture of Place and Solder Decoupling Capactiors (C1, C2)
Note:Orient the minus sign on capacitors to the right side of the circuit board. The long leg must go in the square shapped pin.
Step 10: Place and Solder (R5)
Picture of Place and Solder (R5)
4,700 ohm resistor [yellow, violet, red, gold]
Step 11: Place and Solder 2N3904 Transistor. (Q1)
Picture of Place and Solder 2N3904 Transistor. (Q1)
Note:Orient the flat side of the transistor towards the left edge of the circuit board.
Step 12: Place and Solder 7-segment Display (D1)
Picture of Place and Solder 7-segment Display (D1)
Step 13: Place and Solder Both (CONN3) and (CONN1)
Picture of Place and Solder Both (CONN3) and (CONN1)
(CONN3) - DC barrel jack
(CONN1) - AC cord receptacle
Step 14: Place and Solder the Blue Terminal Block (CONN4)
Picture of Place and Solder the Blue Terminal Block (CONN4)
Note:Make sure the open side faces the right edge of the circuit board.
Step 15: Place and Solder the Large AC Receptacle (CONN2)
Picture of Place and Solder the Large AC Receptacle (CONN2)
Note:This device has 2 solder points on the top side and one on the bottom side of the circuit board.
Step 16: Place and Solder Large Blue Relay (K1)
Picture of Place and Solder Large Blue Relay (K1)
Note:The text should appear upside down.
Step 17: Place and Solder (C1, C2)
Picture of Place and Solder (C1, C2)
Note: Orient the minus sign on the capacitors to the right side of the board.
Step 18: Place and Solder (U2) and (S3, S4)
Picture of Place and Solder (U2) and (S3, S4)
(U2) 5v regulator
(S3, S4) Push buttons
Step 19: Squeeze Your Microcontroller Leads to Fit the IC Socket (U3)
Picture of Squeeze Your Microcontroller Leads to Fit the IC Socket (U3)
Step 20: This Is the Amount of Curve You Are Looking for on the Leads.
Picture of This Is the Amount of Curve You Are Looking for on the Leads.
Step 21: Install the 28-pin AVR Microcontroller
Picture of Install the 28-pin AVR Microcontroller
Step 22: Solder Female Header for HC-06 Bluetooth Module or TTL Uart Access.
Picture of Solder Female Header for HC-06 Bluetooth Module or TTL Uart Access.
Step 23: Connect Temperature Probe to 3-pin Terminal Block.
Picture of Connect Temperature Probe to 3-pin Terminal Block.
Note:The wires must be connected in the correct order. The colors are labeled on the PCB.
  • top: red (vcc)
  • middle: black (gnd)
  • bottom: yellow (data)
Step 24: Flip Circuit Board and Use Plastic Rivets to Attach Plexiglass Base.
Picture of Flip Circuit Board and Use Plastic Rivets to Attach Plexiglass Base.
endotoxin (author)2015-11-26
This is a lovely controller and I use it at least every week to make batches of Yogurt. I plan on buying another when I swap out my fridge for a freezer-convert.
One improvement I can see is an LED to indicate when the relay is engaged current is flowing to your target device. Perhaps one placed inline with R5 would accomplish this. Another item I modified was the temperature probe, adapting it to use a 3.5mm stereo plug and socket for easy cleaning and removal.
About This Instructable
1,519views
17favorites
License:
Bio: I design and sell two different electronic devices. The first devices desulfates old dying batteries. The second assists people with the fermentation of foods. When ... More »
More by sklarm:YATC5 - Temperature Controller Assembly InstructionsDP2 - Da Pimp 2 Assembly InstructionsLocally Harvested and Milled Hearty Mesquite Bread
Add instructable to:
