Yarn Bowl From Yogurt Container
Published
Introduction: Yarn Bowl From Yogurt Container
if you're tired of your yarn running away from you while you're knitting or getting messed up in your bag, and you eat a lot of yogurt, this could be the ideal solution.
You need:
  • Yogurt container
  • Exacto knife or equivalent, or pair of scissors (or both!)
  • Tape (optional but recommended)
Step 1: Clean Out Your Yogurt Container
Make sure it is yogurt-free.
Step 2: Cut Slit for Yarn
Using your scissors or exacto knife, make a slit 1-1.5" long down the side of the yogurt container, starting from the top.
Step 3: Make a Space for the Yarn
Make a hole at the bottom of the slit. I used my scissors to snip away bits of the plastic until I had a small hole.
Optional: line the hole with bits of tape so that the yarn slips through the hole more freely.
Step 4: Done!
Put your ball of yarn in the yogurt container. Feed the loose end of the yarn through the hole, or use the slit to slide your yarn into the hole if you've already started a project. Enjoy having a holder for your yarn that is cheap, made of recycled materials, has a tightly-fitting lid, and won't roll away from where you put it.
    • Spotless Contest
      Spotless Contest
    • Flowers Challenge
      Flowers Challenge
    2 Comments
    I've been doing something like this for years for yarn, string, and twine. I use all kinds of containers but use metal tarp grommets with no slit. Use some clear packing tape to put a piece of the strip on top so you don't have to even open it to know what kind or color is inside it.
    That's a really good idea, and I'll have to start saving yogurt containers for that! Part of the reason for the slit is so that I could take projects in and out, but that wouldn't be an issue for holding balls of twine etc.
