In this Instructable, I describe how to take steel wire for making electrical fences and turn it into split rings suitable for creating a chain maille garment.
While other instructables document weaving rings into garments, or how to construct a mandrel (winding rod and stand), the originality in this instructable is in the winding tool that allows for very reliable, high speed winding, that creates perfect coils of wire every time. (see step 3)
This project is also documented at my personal website.
Remove these ads by
Signing UpStep 1Problem Description
We need a way to make this wire into small, consistent rings. We're going to build a machine capable of winding this wire onto a metal rod to make a long coil of wire. We will then cut individual rings off of this coil.
The way I made chain mail was to get 16g galvanized electrical fence wire, available in a livestock feed and tack store, and wrap it around a threaded rod, turned in a frame by a reversible electric drill. It has a hole drilled through the rod near the end opposite the drill to secure the wire in place. I feed it on in short, slow spurts. You end up losing about an inch (2.54cm) this way, but it is securely attached to the threaded rod, which is much less capable of breaking than would be a dowel.
Id post a picture of my work but my phone hasn't been returned from my sibling yet. mabee later
My two cents: "Bullets were the main reason that men first went from chainmail to platemail" - I understand plate doesn't stop a bullet either, so I think one of us is wrong.
Also, stiletto-type blades were invented specifically to get through chainmail. There's a particular name for these type of "link-breaking" blades, but I forget what. Maybe it's "link-breakers".
