The big difference is that I decided I didn't want to destroy my ATX power supply in the conversion. Another advantage is that you can just plug in a new power supply if the old one goes caput.
Tools:
Drill and bits
Screwdriver ( for taking project box apart)
Soldering iron
Desoldering iron (optional)
Label maker (optional)
Materials
Banana jacks
Project box
A lighted 12V switch
3/4" strain relief
ATX connector (purchased or scavanged)
Miscellaneous heat shrink tubing sizes
Some wire 14-20 Ga (colors matching standard ATX if possible)
Remove these ads by
Signing UpStep 1Obtain an ATX Motherboard Connector
Desoldering components can be tricky, so take your time. The easiest way I have found is to first flood all the pads with as much solder as they'll hold. This allows me to heat the entire pad and pin evenly with the desoldering iron. I use a simple Radio shack model with a squeeze blub.
you power it on and all the lights will go dim in your house =)
But the more I thought about it the more I realized that your comment was a good opportunity to add information that might not be immediately obvious to everybody .
So:
12V - (-12V) = 24V
5V - 3.3V =1.7V
you can't use paired plugs but
12V - 3.3V = 8.7V
etc...
Just be careful using pulling any of these non-rated voltages out of the supply, it wasn't designed from it and there's no guarantee that the voltage will remain stable if you pull any sort of current doing so. I would recommend piggybacking a voltmeter to watch the voltage if you're going to use this trick.
Anyways, I teamed mine up with the Third Hand++, to power the fan and LEDs that I have lighting it. Here's some pics of the one I made:
