3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Yet Another ATX Power Supply Mod
You've seen other ATX power supply mods here on instructables, but this is my version, a bit less refined but it looks nice and most importantly, it works.
Step 1Cut off those cursed Molex connectors!
Tools: Screwdrivers (phillips)
Drill
Wire Strippers
Needle nose pliers
Linemans Pliers
Electical tape / heat shrink
One LED of the desired color (and a 1/4 ohm resistor if you feel the need)
Scrap wire
Spray paint
Sandpaper
This took me around an hour to complete, a bit longer to document and mess with minor hiccups i encountered.
Well, for the most part if your working with an ATX power supply, it has a 20 pin motherboard connector on it, cut all of your wires about 1 foot long, the brown, gray, and purple wires arent necessary,and can be cut shorter, but do NOT cut the green wire, that will go to our switch.
9 comments
Oct 18, 2008. 4:58 PMcarrierpilot1357 says:
done mine. here's some pics.
Dec 25, 2009. 8:49 AMdingo27 says:
those few pics looks better than all in whole article!
Dec 22, 2007. 4:48 PMgamer says:
1/4 ohm resistor? nice project! -gamer
Aug 13, 2008. 8:50 AMelectronic nut says:
1/4 ohm resistor means ,25 percent tolerence of going over the resistor's resisting voltage
Aug 13, 2008. 10:06 AMgamer says:
1/4 ohm resistor, you've got something wrong... That would be 1/4 watt, wouldn't it be? -gamer
Aug 29, 2009. 4:23 PMdagenius says:
no, he's talking about 25%. watt is not tolerence.
Mar 14, 2009. 4:41 PMN1CK4ND0 says:
Very nice, unless your power supply already has a built in power switch built in lol :p
Dec 22, 2007. 5:27 PMMr. Rig It says:
Frank, Please allow me to constructively criticize you instructable. First the negatives 1.You have a nice idea here but the title is misleading. 2 You don't tell what the idea/thesis of the project is. It is only a couple steps later that this is identified and a power switch modification to an ATX case. 3. Proper capitalization of the word I (instead of i) would help. 4. Pictures could be a little better, but some pictures are better than none. Now the positives 1. Pretty good documentation of how you did it. 2. Cool idea. 3. Gives you the opportunity to use this same power supply in other Instructables 4. Nice work cleaning up and bundling all of the wires. The project came out nice. Thank you for not taking my observations personally. Good luck and keep'em coming.
Dec 22, 2007. 3:29 PMGorillazMiko says:
good idea! :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:frank113
well im a strange one , ill admit that otherwise im kinda normal
