Yet Another DIY Wii Sensor bar
I've found that the included Wii sensor bar wouldn't allow me to play games far enough away. This could've been due to the actual width limitation of the bar or the strength of the LEDs. Since I use a front projector setup, this required wiring together a solution that allowed the sensor bar to be placed anywhere (and overcome the 10 ft wire extension distance) and also extend the range of the play.
Following the DIY sensor bar initially created by Doctabu, I created one of my own.
My requirements was that I move the Wii around and needed flexibility on the actual play distance. To do that, I wanted two IR LEDs that could be easily repositioned. Thus, a quick trip to the local electronics store yielded me 2 infrared LEDs, 2 battery holders and 2 resistors and 8 AA batteries.
I was aiming for brightness in the IR spectrum and some research had shown that LEDs with a lower 850nm wavelength produced higher degrees of brightness than the higher wavelengths. In the end, my electronics store had a limited selection anyway. The LEDs I was able to obtain were 1.7 forward voltage with a peak current of 50mA. I had a 4 x AA battery pack so that required a 100ohm resistor for each. If you have any other type of LED, your resistor requirement would change. For example, if you choose to use a 2 x AA battery pack for this LED, you'd need a 56 ohm resistor.
Once complete use a digital camera to see the IR light and check that your connections work.
I've attached a spreadsheet to calculate the right width that the LEDs need to be spaced apart for any given play distance.
Step 1Back and Soldering
Back and Soldering
Luckily, there was just enough space to drill a hole and fit the LED and resistor inside. The resistor is important to prevent the LED from burning out.
17 comments
Apr 20, 2011. 12:27 AMhondaman900 says:
There's a great new kit version of this on Kickstarter http://www.kickstarter.com/projects/1621263610/the-megabar-free-your-wiitm
Seems to be a more complete system. I like their father-son kit idea.
Aug 2, 2010. 10:03 AMshakespeare1212 says:
I found a little window burgaler alarm at the dollar tree store. I had the batteries, battery compartment, and a slider switch included for $1. I got rid of the speaker and some the the components on the circuit board. I wired in a 22 ohm resistor, and a VISHAY TSAL 6400 IR LED and a green visible LED (to be a power on indicator). It works great. Either with the Wii console or with Smoothboard.
Mar 11, 2007. 7:53 PMFenwick says:
Is is absolutely necessary to use 4 AAs per LED box? How well would it work with just 1 or 2 AAs?
Mar 13, 2007. 5:33 PMFenwick says:
I made mine, with 2 AAs, but they look really crappy because I just soldered the components and electrical taped them on top. Oh well, not lookin bad for my first ever soldering job :P.
Jan 8, 2010. 9:27 PMflyingpumpkin says:
you really should not use the LEDs without a current limiting resistor.  You will eventually fry your LEDs. especially since the batteries don't evenly divide into the voltage.
You are are just going to eat through half the batteries twice as fast.  It will be the same thing.  You could use 2 LEDs and run them off of 2 1.5 volt batteries (any kind AA AAA, AAAA, C-cells, D-cells anything as long as you get 3 total volts)
If it were me I would use C-sized batteries (and a resistor).  they will last for Eons.
also radioshack high output LEDs are 1.28volts not 1.7 volts...
Aug 6, 2008. 6:42 PMi make shooting things says:
id put another small red led in so you can tell whether is on with out looking at the switch
Jan 8, 2010. 9:22 PMflyingpumpkin says:
Actually you probably can't for two reasons
1) the different voltage/current requirements of the red LED might cause problems. You could wire it up in parallel with it's own current limiting resistor but that seems like a hassle.
2)it is going to eat up your battery time.  I would only do it if you are running it off of a power-supply
Nov 7, 2009. 3:07 PMfreshprincem218 says:
 the wiimote has an infared cam in it right all you need is two candles place on tv light them up and your wiimote should react to it trust me i tried it
Mar 6, 2008. 4:52 PMSheol says:
I'm a bit of a novice when it comes to soldering. Did you cut the negative wire completely and just solder the LED to the component on the far left. Also the closest LED I could find with these specs were a pair of emmiters and detectors, which do i use?
Jul 16, 2008. 9:59 PMbmlbytes says:
Use the emmiters. They emit IR light and the detectors detect the IR light.
Mar 15, 2007. 9:27 AMmchoffa says:
I used your design, but ended up using 10mm LEDs, 850nm. 2 in a series on each box. Each box holds 4 1.2V AA 15 minute rechargeable batteries, and I used a 22 ohm resistor. So far so good, except that I guess the spread angle is not great on the LEDs I bought. so I pretty much have to be facing directly at them. Basically I have to angle them slightly up to use them standing up, angle them straight when sitting down on the couch, but my range is huge now and accuracy from way back is MUCH better.
Mar 7, 2007. 11:02 AMmchoffa says:
This is exactly what I was looking for. My only question is, would it be a good idea to have 2 or 3 LEDs in each box slightly angled apart, or would I get the same results with just one pointing straight forward? Being in a large room, multiple players tend to be further apart and I didn't know what kind of playing angle the single LED allows. How is this setup working out for you?
Feb 22, 2007. 7:23 PMfrank26080115 says:
Wow, I could've swore you used a project box, very nice. i have an idea, a foot pedal switches the normal distance set of LEDs with a group of more farther apart LEDs thus you can step on the pedal and have a instant boost in pinpoint control, basically you make the wiimote think you moved closer to the screen when really you didn't i never played a wii so i don't know if that sounded practical
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:strangesnow
