Following the DIY sensor bar initially created by Doctabu, I created one of my own.
My requirements was that I move the Wii around and needed flexibility on the actual play distance. To do that, I wanted two IR LEDs that could be easily repositioned. Thus, a quick trip to the local electronics store yielded me 2 infrared LEDs, 2 battery holders and 2 resistors and 8 AA batteries.
I was aiming for brightness in the IR spectrum and some research had shown that LEDs with a lower 850nm wavelength produced higher degrees of brightness than the higher wavelengths. In the end, my electronics store had a limited selection anyway. The LEDs I was able to obtain were 1.7 forward voltage with a peak current of 50mA. I had a 4 x AA battery pack so that required a 100ohm resistor for each. If you have any other type of LED, your resistor requirement would change. For example, if you choose to use a 2 x AA battery pack for this LED, you'd need a 56 ohm resistor.
Once complete use a digital camera to see the IR light and check that your connections work.
I've attached a spreadsheet to calculate the right width that the LEDs need to be spaced apart for any given play distance.
Remove these ads by
Signing UpStep 1Back and Soldering
Seems to be a more complete system. I like their father-son kit idea.
You are are just going to eat through half the batteries twice as fast. It will be the same thing. You could use 2 LEDs and run them off of 2 1.5 volt batteries (any kind AA AAA, AAAA, C-cells, D-cells anything as long as you get 3 total volts)
If it were me I would use C-sized batteries (and a resistor). they will last for Eons.
also radioshack high output LEDs are 1.28volts not 1.7 volts...
1) the different voltage/current requirements of the red LED might cause problems. You could wire it up in parallel with it's own current limiting resistor but that seems like a hassle.
2)it is going to eat up your battery time. I would only do it if you are running it off of a power-supply
