Yet Another - High Brightness LED (HBLED) Aquarium Lamp
 by jimk3038
Step 2: Deigning & Building Lamp
What better way to transfer heat than to use a glass plate. The glass plate transfers heat very well. The glass is also inexpensive - glass plate is less expensive than Plexiglas. I simply used some picture frame glass that I already had laying around the house. I cut two plates 18" x 3 1/2" with the idea of sealing the LEDs between the two plates. The open gap around the edge of the glass is then sealed with a bead of silicon sealant. Once sealed, the glass seems very solid - the two plates glued together makes them much stronger.
During assembly, the LED carrier boards are super-glued right onto the glass. I used 24 LEDs in total. Of the 24 LEDs, 5 are warm white and 19 are blue. This gives me 125 lumens of warm white and 114 lumens of blue.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
