Of course, there are a couple of instructables that already feature such a circuit, but I was unable to get them to work correctly for whatever reason. This being the case, I will now present the circuit that I came across and works very well.
Remove these ads by
Signing UpStep 1Yet another overview
For example. Say that you wanted to control the brightness of an led (note: there are many ways to do this, but for the sakes of an example, I'll only note two). The first way would be to put a variable resistor in series with the led. This would alter the amount of current that went through the led, while holding the voltage constant. If you put the variable resistor at 40%, the led would be 40% as bright as it could be.
The second way would be to connect a led in series with a resistor and a power supply that could be turned on and off really quickly. Let's say that you were able to turn on and off the power supply quick enough to the point where 40% of the time it was on, and 60% of the time it was off. This would be reflected by the led being on full brightness, but only for 40% of the time, giving the illusion of being 40% as bright as it could be.
Two different methods, for the same result. What's the difference? About 60% of the energy gets burned off as heat in the resistor in the first circuit, while in the second circuit, almost all of the energy supplied is used.
This is why PWM is useful. It allows a signal to range from completely off to completely on. If a signal is turned on and off quick enough, given a certain ratio, a signal can appear to be that ratio, without suffering from much power loss at all.
I know it's my own ignorance, but there is not info here for me. The levels of the readers electronics knowledge varies greatly.
Like for me, I don't see how this even works since I can't find where to attach the power, where it comes out. I have to figure out ground, might be the (-). I know it's me, but help a guy out and label those things.
Keep in mind that the people that can read this cold, probably know how to do it already.
Thanks
The 555 IC can take a voltage of between 5-15v, which means that you could power it with a simple 9v battery. In schematics, Vs stands for Voltage Source, which is where you would plug the positive (+) terminal of the voltage source, while the triangle (in the first picture in this step) is where you would connect the negative (-) terminal.
Schematics that have multiple ground symbols in actuality only have one. When creating the circuit, all of those ground symbols will connect together and meet at the battery's negative terminal.
The output voltage, where the signal is generated, comes from pin 3 on the IC.
Remember, all grounds meet together, unless otherwise specified.
