I've been wanting to make one of these since I saw the Good Eats episode that introduced it. My friend recently had a birthday, and he is a meat fanatic, so I figured this would be the perfect time to build one!
If you haven't seen one of these before, it's a cheap, home made version of a ceramic meat smoker, such as the Big Green egg. The terra cotta acts as a terrific insulator, allowing you to hold high temperatures for several hours for some delicious flavor!
This is my first Instructable. I know there is definitely room for improvement, and I definitely stumbled through it, but I was satisfied with the end result.
Remove these ads by
Signing UpStep 1Grill!
you are going to need somewhere to hold your meat inside your smoker. In our case, we'll be using a BBQ grill. If you or someone you know has an old, rusted BBQ, re-use! Otherwise, the hardware store has replacement grills.
I could only find 3 different grill sizes. I put this step first so that you can choose what size of grill you want before you proceed. While you're in the BBQ isle, also pick up a replacement grill thermometer (not a meat thermometer). More on that later!
I made the mistake of starting with the pots without measuring the diameter of my grill first. I just eyeballed the pots and thought that my grill would fit. Close, but not quite.
So think before picking your grill. Big grill means more surface area for cooking, but also probably means you are going to need big pots to hold it. Maybe not the best solution if you have limited space to work with.
5
comments
Add Comment
BigCountry
says:
Add Comment
