Yet Another Fume Extractor
1,365
56
6
Posted
Introduction: Yet Another Fume Extractor
I made this fume extractor from an old pc fan and a yogurt cup. (I should have taken more pictures, sorry)
Step 1: Gather Materials
You'll need:
- a 12v pc fan
- a cup or any housing that fits your fan
- active carbon filter
- a switch
- a power source (I used a 12v wall adaptor + the matching input jack)
- a soldering iron
- hot glue
optional:
- a potentiometer (I had a circuit lying around that came with my pc case)
- spray paint
Step 2: Fit the Parts
Tie a rubber band through two of your fan's screw holes. Cut out the bottom of your cup leaving a ledge to hold the carbon filter. Cut slots in the rim of your cup to hold the screw holes of your fan as seen in the picture.
Cut the wires you don't need: we only need black (ground) and red (12v). Blue and yellow are tachometer signal for the pc mainboard and pwm, I believe.
Cut the carbon filter sheet so it fits snugly in your case.
I also had to trim the circuit board of my potentiometer circuit using a dremel to fit into my cup.
Step 3: Assemble
Drill holes in your casing to put the switch, poti and power jack through.
Glue the circuit, switch and jack in place using hot glue.
Put the layers of carbon filter in place.
Put the fan in place and attach the rubber band around the rim of your cup.
Make a test run.
If everything works as expected, you can paint it.
Hope you like it!
  • Metal Contest 2017
    Metal Contest 2017
  • Wheels Contest 2017
    Wheels Contest 2017
  • Remote Control Contest 2017
Questions & Answers
6 Comments
This is awesome! Now you don't have to breathe in the nasty fumes.
Nice job on your first Instructable and thanks for the clear photos! I hope we see more from you in the future!
you will :D
what's it used for?
to suck away and filter the harmfull fumes that develop while soldering
Love the dairy Container :P That Paint job gave it a nice finish !
