Yin-Yang Zen garden
 by oi2342001
Step 4: Building the rake
I forgot to take pictures of the rake as I was building it but it is very simple (I'm sure you could find a good instructable for how to make the rake if you do a search for it).  I took the 1/2" dowel and cut a piece about 1" long.  I then drilled 2 holes into it about 1/4 of the way in from each side between 1/4" and 3/8" deep.  You don't want to go all the way through for these 2 holes.  Then in the middle going at a 90 degree angle to the 2 holes I just drilled, I drilled a hole through the dowel.
I took the 3/16" dowel and cut a piece about 6" and stuck it through the hole the goes all the way through the 1/2" dowel.
I then cut 2 small pieces of the 3/16" dowel about 3/4" long and stuck each one inside the holes and sanded them down making them the same length.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
