Step 5Fitting the beanie
iImage Information
You've probably noticed by now that when draping the body over yourself, it tends to slide around a bit. To fix this, you'll need to attach your beanie to the inside, right where you've marked the center of the top of your head. You can use large safety pins to get a rough position, then lock it down in place with smaller ones around the rim. When adjusting the placement, be sure your eyes are just beneath the upper edge of the mouth fabric, so you can see out through the mouth. However, you don't want your eyes to be too low into the mouth, or it may look like either your Yip-Yip is always looking down, or it's upper lip is wrapping around your forehead.
