Yolo Manicure
Introduction: Yolo Manicure
Step 1: Pick Two
Pick your two colonies that you want
Step 2: Base
Put your base coat on first
Step 3: Base Done
Once you have your base coat done you will need a tip to draw a design on your nails
Step 4: Just a Tip
If you need a tip 2 draw cut the end of a q-tip
Step 5: Dip
Dip your tip into the nail polish 2 get the colour
Step 6: Yolo
Use your tip and draw yolo make sure that you start from your pinky
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    Try a tooth pick use dots and connect them it will make everything a lot better
    Using a cut q-tip to draw is a great tip! It would probably work a little better if you scrape the extra nail polish off the q-tip into the bottle before drawing.
    That's so cool but what does yolo mean??
    "You Only Live Once."
    Most people like to let YOLO encourage them to try new things and not be afraid of failure or judgment... but don't let it trick you into doing something unwise! Driving a golf cart down a hill while blindfolded is not a good YOLO situation. ;) Dyeing your hair green to show your favorite team support probably is.
