Introduction: Yorkshire Puddings Made Easy
Picture of Yorkshire Puddings Made Easy
These instructions are written to help competent cooks easily prepare homemade Yorkshire Puddings.
For me it started out as a process of trial and error. I tried using verbal recipes from relatives - and failed. Then I tried other peoples' recipes and an old cookbook but found these resources do not include very important information which can mean the difference between success and failure.
I nearly gave up but then decided I was going to see it through. It wasn't too long before I found some more encouragement from friends and the Internet and figured out how to make it all work for myself. This recipe is probably the same recipe most people use. I've been able to repeat these steps week on week to re-produce the same great results and I'm sure you can too!
Step 1: You Will Need
Picture of You Will Need
Ingredients
  • 2 Eggs
  • 1/2 cup Semi Skimmed Milk
  • 3/4 cup Plain Flour (or heaped half-cup as pictured)
  • 1/4 tsp Salt
  • Vegetable Oil
Optional Ingredients
  • 1 Tablespoon Herbs such as Sage, Parsley, etc.
  • * I included a few photos of a batch containing 1 Tablespoon Parsley for comparison.
Equipment
  • Pyrex measuring cup
  • Dry ingredients measuring cup
  • Whisk
  • Muffin pan or Yorkshire Pudding pan
  • Oven mitts
  • Cooling Rack
Yield: 12 Yorkshire Puddings
Step 2: Pre-heat
Picture of Pre-heat
* Check the oven shelves are placed low enough so the Yorkshire Puddings have plenty of room to rise. For a standard oven the muffin pan should sit in the middle of the oven.
* Pre-heat oven to 220 degrees Celsius or 425 degrees Fahrenheit
* Pour oil approx. 1 millimeter deep in the muffin cups. There should be just enough oil to cover the bottom of the cup.
Step 3: Mix
Picture of Mix
* Whisk eggs into Semi Skimmed Milk until fully mixed
* Add Plain Flour and salt to the egg/milk mixture and mix-mix-mix with the whisk.
* You should end up with a nice smooth batter which contains lots of small air bubbles from whisking.
Step 4: Bake
Picture of Bake
* Immediately after whisking, pour batter into muffin pan cups. The cups should be approx 1/3 full with batter. The oil rises up to sit on top of the batter and should reach just over halfway. Don't worry if the oil doesn't completely cover the batter.
* Ensure the oven has fully heated to 220 degrees Celsius. If the oven hasn't pre-heated then the Yorkshire Puddings will not rise properly.
* Put the muffin pan into the oven and turn up the temperature from 220 Celsius to 230 Celsius / 450 Fahrenheit for the duration of baking.
* Bake 30-40 minutes.
* Using oven mitts, carefully remove the Yorkshire Puddings from the oven when just darker than golden brown. It is usually easiest to remove them from the muffin pan as soon as they are out of the oven. BEWARE there will be piping hot oil in the middle of the Yorkshire Pudding but this can be gently poured out as you remove them from the pan.
Step 5: Tips
Picture of Tips
* For light/fluffy Yorkshire Puddings like the ones at Toby Carvery, reduce the amount of Plain Flour from 3/4 cup to a leveled 1/2 cup.
* Farm Shop eggs make the batter rise better than supermarket eggs. This recipe was written based on results with supermarket eggs. You may find you can reduce the recipe down to one egg if using Farm Shop or good quality free-range.
* Optional Ingredients for the batter include herbs such as Parsley and Sage.
* For a sweet option, place sliced apples in each cup before baking.
* Do not open the oven during baking. The Yorkshire Puddings will not rise properly if the oven door is opened while they are rising.
* Always use Plain Flour. Self raising flour will not drop in the middle and you will end up with "popovers" instead of Yorkshire Puddings.
* With this recipe there is generally no difference when pre-heating the oil in the pan before pouring the batter.
* There is no difference when cooling the batter in the fridge before baking. In fact I prefer my batter freshly mixed.
* To avoid oil spillage in the bottom of the oven, line the bottom of the oven with foil or an old baking sheet.
* I have also used this recipe with a Pyrex baking dish to make Toad in the Hole (I pre-cook the sausages before putting them in the batter).
* Since learning to make my own Yorkshire Puddings I've enjoyed the extra freezer space from not buying Aunt Bessies. I believe they taste better and are cheaper, too.
TheCoffeeDude (author)2015-12-24
Tried this and now my girls are totally hooked on Yorkshire pudding!
urtweetsboreme (author)2015-06-29
The biggest secret to these is to use warm milk, warm eggs, and even warm flour. I thought these were hard to make until someone shared this tip. I never let the batter stand more than a minute while prepping regular muffin pans with a little lard, but they rise every time.
Straklin (author)2015-02-16
Nice instructable! I would love to see your Toad in a Hole recipe. I have never heard of it. Also, do you put any beef drippings in your Yorkshire Pudding? I have seen recipes with it before, but not here. Thanks!
ColleenW3 (author)Straklin2015-03-10
Thanks for your feedback. I will get some photos to put together an Instructable for Toad in the Hole sometime soon.
Drippings will have been used traditionally for making Yorkshire Puddings. The vegetable oil in the muffin cups is a substitution for beef drippings, or lard. I assume Vegetable Oil is a healthier option, however in our house, the drippings go into the gravy so we don't see much in the way of health benefits. On a few occasions I've used drippings and topped it up with lard (because it would take more drippings than I tend to have for a full dozen batch). If the dripping and/or lard is in solid form (ie. out of the refrigerator) then you would need to heat the pan enough to melt it to liquid form before adding batter to the cups. The resulting Yorkshire Puddings will look the same regardless of whether you use drippings, lard or oil. As long as you can achieve the high heat needed for the batter to rise, that is the key.
mountainmasha (author)2015-02-17
I made Yorkshire pudding for the first time over Christmas and loved it. I really like that this way you already have individual portions. Thanks for the tips!
jlaurence1 (author)2015-02-16
254-105-5976
About This Instructable
1,169views
46favorites
License:
More by ColleenW3:Ikea Billingen Insert Improved Fit for Malm DrawersSeed Bead Storage from a Reusable ContainerIPOD Storage Tin or hiding place
Add instructable to:
